It all started when my turbine was leaking therefore white smoke coming out, had it repaired with Turbo Tong and now there is still white smoke (not much as before)but only at high boost. My question is whether those smoke comes from the retained oil in the piping which i didnt clean before installing the new turbine or piston ring kong? ive checked the compression and its normal for all 4. Need your advice on this. Thanks
