optimized Porsche Gembala 911 - lighting speed by detailien
kc2
1,354
1,410
thedetailers.blogspot.com
microfibers
Microfiber Explained
micro fiberWhat is Microfiber?
Imagine a microscopic plastic wire that cuts through and breaks apart dust, dirt, grime and moisture, and then picks it up like a magnet without scratching the surface. This is what microfiber does when cleaning. Our microfiber is a revolutionary thread, comprised of wedge-shaped polyester filaments and a core of nylon. Made of both oil-attracting and water-attracting polymers, the fibers are woven into masses of tiny "hooks & loops." The sharp edges of these millions of "hooks & loops" cut through dried-in stains, attracting and absorbing dirt and microparticles. The fibers are actually positively charged which increases the attraction of dirt because it carries a negative charge. Each strand is hundreds of times smaller than a human hair and ten times finer than silk.
So how does it work? Is microfiber presoaked in some kind of chemical?
No, it is not treated with any chemicals. The fiber's wedge shaped filaments follow surfaces, lift up dirt, trap particles inside the fiber, and eliminate the need for harmful cleansers. The capillary effect between the filaments and nylon core creates a high absorbency, which in turn enables it to clean and polish at the same time. Only water is needed as a detergent to clean any type of surface.
Cleaning with microfiber is fast, easy and environmentally friendly. With microfiber products you rarely need to use chemicals. It is sometimes described as having a magnetic attraction to dirt and dust. Our products are extremely soft, and they never scratch any surface, but at the same time they are sturdy and tough on dirt. The secret behind the technology is the blend of microscopic polyester and polyamide fibers which are split in such a way as to create microscopic "hooks" which act as claws that scrape up and hold dust, dirt, and grime. They can also absorb up to 7 times their weight in water. This absorbent property is the reason why it will never leave streaks or water spots on any surface even when used wet. The gentle scrubbing properties of the ultra-fine fibers allow you to buff out old water spots safely, even on plastic windshields and tinted window film.
branded flown in from USA....must be good but expensive
cheaper but still not cheap enough
most reasonable....& yet not that cheap too
i recommended to chance 3-4 sets of microfibers per year....otherwise the worn out will marred your paint
We have given out thousand of Microfibers in sharing..
our passion...
You do not judge a book by its cover.....but you judge the detailer by the cloths he uses....
it is a known fact that cotton towel, old worn out rags or towel marred the paint....
simple as 123 or ABC with futuristic car care products
to this
ta da
quick swift & effective detailing
back
my buddy does not his care taker to lay his hand on this ride
ta da
would you allowed your ride to be wipe each time with good de morning towel
this is the effect of using an improper cloths, maybe worn out microfibers to wash.....& harsh chemicals or cleaners used...
how does an apple kept fresh....we may store inside the fridge or wax it on....so it is not the matter how clean we can clean our cars...but is it protected against this harsh ...hot & humid weather of ours....
The chemical which these road side car wash used is to strong & acidic...you can never wash a white car whiter than theirs but is it safe...does they too remove the very layer of wax you put on.....
to this
I shared with my detailing buddy...how easy & effective a simple weekly regiment...to maintain yr ride...rather than he sent it to a car wash to be wacked again (aka Bruise & scratch)
we meet & detail in this back lane
ta da
what we did was
ONR WASH - with 3 microfibers (15 minutes)
Clay - with ONR as LUBE (10 minutes)
ONR wash AGAIN (10 minutes)
OPTI seal - (10 minutes)
OCar wax - (5 minutes)
total time used : 50 minutes
water : 8 litres
Tada
look at the side
so chances are when you buy an expensive microfibers you would not change it frequently
get a reasonable & yet you can replace them fequently to avoid swirls & scratch in avoid paint correction & in resulting hologram
driving must be fun....and maintaining it should be fun as well & not a drag
Guys .... some info about where you can get a bolt on supercharger around klang valley, kl will be very helpful .. in which is suitable for certain car makes...and the estimated price for it :D.... for my case.. i'm actually looking supercharger for mitsubshi engine...namely4g92 mivec... if any of you SIFU out there knows where can i get my hand on them .... oh please let me know ya :)
