nissan fairlady sportrim
kelvin chai
Mar 28, 2011
6
petaling jaya
hi bro , this the 1st time im using the channel , hope urs can giv me some advice , thank
i thinking the change my gold in colour fairlady , ( 17" original ) so what side should i go for it , what colour , where's the best place , beside that where can i get the auto start remote , and this giv give us alot of mantainance ? thank everybody ..
kelvin chai
016-248 3118
kelvin chai
6
petaling jaya
what the 17" rim as compare to 18" and 19" feeling on cornering ... do there giv alot off defrence when hv bigger wheel and slimer tyre ? thank
ysl
192
20
B'worth/Penang
To have a better cornering feel, change to wider tire, you can feel big different in handling between 265 and 245 (same tire brand and same model)
Tire profile doesn't help a lot.
kelvin chai
6
petaling jaya
thank ysl , i still cant decide , my car carrently is 17" original FL rim , should i change the rim ? if cahnge . can go for taiwan rim ? cost is almost 3time compare to japan rim ? so what should i do .....thank :hmmmm::hmmmm:
Z-Ice
323
The fairlady is rear whell drive, hence you need to be careful when taking corners in high speed, easily over steer. Changing rims doesnt really affect much, I agree with ysl. Bigger tires perhaps, however, the set back is when under wet road conditions, you have to be even more careful. The disbursement of water is much more difficult say if you opt for 275 tires for the rear.
Upside is your car is better looking.
Downside - more costly to change tires if you opt for 19inch and above.
- under wet conditions, cannot go too fast.
Always remember, rims don't matter, the type of tires are most important. You can have the lightest rims, but bad quality of tires, its still the same.
For handling, you have to also look at changing your dampers and shocks.
HBS
226
164
1,543
Bigger & wider rubber profile....give your even greater hard braking ability without too much tailslide on the rear end like standard issue tyres profile.
Hi i want to know where can i find those recommended mechanic around setapak area? I using sumething like saga 8v and 4g91 carb on my satria 4g13p,got 2 venturi..will kick in more power when we press the pedal until can feel the power kick in and pedal become more lighter(sometime like vtec,LOL)..now i encounter this problem la..i did sent my car to workshop for top overhaul and pnp,but after took back my car,i found out no performance gain..somemore now my car sometimes will jerking on low...
