Hi guys.....i need help if any one know what wrong with my gen 2....year 2005 1.6(m) and the problem is like this....when i start my car the rpm meter reach till max and the engine is running like 3 piston.....plug in the computer diagnosis and all the faulty code thins has change like the O2 sensor,crank shaft sensor up and down also change,ignition coil also change new and yet still cannot solve the problem and the check engine lights still on and the best is the rpm will reach max.I even try changing the computer box and yet the problem is the same....FYI i did not do anything to the car and this problem just came out of the blue...
I hope there is someone out there that can help me....been going thru a few expert foreman and yet cannot solve it.:hmmmm:
