Need help from senior
wqu3412
Need advise how to setup my ice system
Player:Clarion DXZ935
Speaker : Ameron 6" (front), pioneer 6" (rear)
Subwoofer : 2 unit 12" Ameron 2 coil
Amp : ameron monoblock, 4-channel amp for speaker
thx:hmmmm:
got 3 rca preouts from the hu rite?
front and rear out go to the 4ch amp, sub out go to sub amp
set high pass for the front and rear around 60hz, either on the amp or from the HU, not both
set low pass for the sub around 60hz, either on the amp or at the HU, not both
check the ameron sub is stable down to how many ohms. if stable down to 1 ohm u can connect the 2 dvc subs parallel-parallel. if not stable connect it parallel-series.
When i play a song from cd, the sound from speaker & Sub woofer not nice, any comment of suggestion
---------- Post added at 11:46 PM ---------- Previous post was at 11:35 PM ----------
Another help, which brand is a good rca cable for a good sound?
perhaps its time to change decent component set... last time i did listen to amerion demo car... the vocal point quite weird.. :P
good cable aaa... ermmm PSI???
A thread every 60 seconds
