Need to have better sounding for ur active set up? Here u go...Japan Made Nakamichi Crossover (EC-200 & EC-200H)..a total of 8 channel crossover(4 pairs of RCA out-4 way).
EC-200 2-way (midrange/woofer) adjustable electronic crossover
EC-200H 2-way (tweeter/midrange) adjustable electronic crossover
2 channel Just for tweeter.
2 channel for your mid speaker.
2 Channel Just only for Sub Woofer..
2 Channel for Rear speaker..6''x9'' or 2 ways speaker..
SPECIFICATIONS
EC-200
Maximum power Consumption: 0.53W
Rated Current Consumption: 40mA
Attenuation Slope: 18dB/octave
Crossover Frequencies: 50, 70, 100, 150, or 220 Hz (independent selection for low-pass and high-pass sections)
Total Harmonic Distortion: Less than 0.003% (1kHz, 2V)
Signal-to-Noise Ratio: Better than 105dB
Input Level/Impedance: 1V/100kohms
Output Level/Impedance: 0-2V (variable)/5kohms
Maximum Input Level: 3.5V
Power Source: 14.4V DC, negative ground (10.8V - 15.6V allowable)
Dimensions: 120(w) x 35(h) x 105(d) mm
4 3/4(w) x 1 3/8(h) x 4 1/8 (d) inches
Approximate Weight: 320g/11oz.
Faster..drop me ur offer for the miracle item.
Super good performance stuff..
p/s : not suitabe for those running passive set up as u need at least 8 channel Amp(4 X 2channel amp or 2 X 4 channel amp) or 6 channel + 1 monoblock..
SPECIFICATIONS
EC-200
