- Joined
- Feb 8, 2006
- Messages
- 2,293
- Points
- 1,648
GUYS...
JUST DID A LOT OF READING. My conclusion is:
Dont waste money on changing to those low resistance
plug cables. Plug cables are servicable parts.. mean u must
change regularly also. Maybe every 50k~80k.. not sure.
Most plug cable say they increase hp la what la..
actually tests hv been done, they DO NOT increase
ANY HP AT ALL. But u can feel it right? Why?
It is bcos ur prev cable oledi deteriorate. So u merely
restore the lost power. U can get same effect if u
change standard plug cable into brand new one.
Same like when u just svc.. new oil.. feel power right?
Normal spark at plugs will burn fuel+air mixture
the same way as a bigger spark. there will be
NO residue fuel+air mixture after sparking!
U can try this.. put ur cooking gas in equally
sized plastic bags, one u burn it with matches,
another u burn it with cigarrettes. The fire is
same size right?
The only hp u can gain is by increasing fuel+air mixture.
example:
Increase air flow. (chg to those high flow air filter) or Super/Turbocharge it.
Increase fuel intake (or course) (chg bigger cc fuel injector).
Piping.. etc..
Digress..
When u chg low resistance cable, sure spark is
bigger... but it will cause interference to ur
electronics.. and ECU! and will cause misfiring
and eventually Lost Power.
If you want to change cable, I recommend the
stock cable. Brand new.
My friend and I also experience by testing a few plug
cables. For me, I bought Taiwan 9.5mm plug cable
put to my prev wira 1.3. I felt power increase..
but then when ON the radio, I heard noises.
I used it for 1 year plus... then I wanted to sell
the car. So I took the cable out and I bought
ori Wira plug cables and to my surprise, it felt
MORE POWER than the 9.5mm one!!!.... My friend
even bought NGK Power Cables.. cost RM300++.. after he use
for half year.. then he tried chg to his old stock cable
again.... NO DIFFERENCE!...
My advice is if u want to chg cable, and dowan
the stock one, better find a cable that can
LAST LONGER and keep its quality to conduct
the sparking for long time...
What U THINK?
same size right?
example:
Piping.. etc..
Digress..
What U THINK?
