- 100% Brand NEW.
- MOTUL Diesel System Cleaner
- Original Motul.
- Price excluding GST 6%.
TYPE OF USE:
MOTUL DIESEL SYSTEM CLEAN is designed to be used in all types of Diesel engine with direct or indirect injection, naturally aspirated or turbocharged, with or without catalytic converter. MOTUL DIESEL SYSTEM CLEAN effectively cleans dirtying and clogging which appear in the whole Diesel fuel system :
- condensation in the fuel system
- gumming in the injection pump
- injector nozzle fouling
- dirtying of combustion chambers and inlet valves
MOTUL DIESEL SYSTEM CLEAN provides a perfect lubrication during cleaning phase and prevents removed micro-particles from depositing. Moreover, it prevents from Diesel fuel oxidation and microorganisms formation.
PERFORMANCES
A clean fuel system is a necessary condition for an effective engine running. MOTUL DIESEL SYSTEM CLEAN allows to :
- clean the pump and the injectors (for a better atomisation of Diesel fuel)
- prevent the formation of deposits and varnishes on inlet valves and in combustion chambers
- disperse condensation water in order to avoid any fuel system oxidation
A regular use will provide :
- easier cold starting
- fuel savings
- optimum engine performances
- increased lifetime of fuel system and catalytic converter
- a reduction of exhaust pollutants emissions (smoke, particles…)
RECOMMENDATIONS
Directly pour one can of DIESEL SYSTEM CLEAN in the tank before refuelling, regularly, depending on the use (shorten intervals in urban use). The fuel system will be then completely cleaned, from the tank to the combustion chamber. A can is sufficient for tanks up to 60 litres. For bigger tanks, the recommended mixing ratio of Diesel System Clean is 0.50% (200:1). Do not exceed the recommended proportion. If necessary, proceed to 2 successive treatments.
Curative treatment : use the product pure by plugging on the fuel system with the adaptation kit.
Location : 22M,1st Floor, Jalan Pandan Indah 1/23A, 55100, Pandan Indah,KL (Look for Sign Board JASMA, above Trinity Pharmacy).
Payment option:
- Online Payment/Postage:
- Original Motul.
TYPE OF USE:
PERFORMANCES
- fuel savings
RECOMMENDATIONS
Payment option:
