This item is brand new and it will fit the 3 plugs version of EVO8 and EVO9.
This is better than a Universal M800 if you use it on an EVO8 or EVO9. Reason for that is because the adapter board has all the extra circuitry build-in like the build-in barometer which act as a second MAP sensor so if you ever drive the car to Genting, the tune will still be good(you know what I mean if you do your homework = P ). For the CAN connection, there is a proper resistor onboard as well.
This is the exact same board which Mitsubishi uses on the FQ400 EVO8.
Buy this board instead of the M800 universal and save the money and effort without having to do all the extra wiring harness work.
PM me for more detail.
