mohawk red 12 double coil
ICE_addict
20
to all otai in car audio...
please help me,i'm using mohawk double coil woofer(Red12)...so what power amp that suitable for my woofers...can hantam the woofer la...plz help me...for information i'm using two 12 inch woofer...
Zenn
2,799
43
1,648
ICE_addict
20
alamak Zenn rms tak tau la...have to open back my woofer...buy pun 2nd hand one...is it true i have to pakai monoblock???if combine amp can???i have hunter 1900w and sony xplod 1600w...can i combine those two to support my woofer
Zenn
2,799
43
1,648
alamak bro kat tepon pun susah nak cite ni.......
takpe aku assume mohawk ni requirement dalam 300W, tapi ko kena la bagi spec utk amp hunter or sony tu plak, pilih mana lagi kuat, pakai yg tu, dua-2 sekali takleh.
kalau nak jual the 2 amps, then look for new one, cari yang boleh turun 1ohm macam monoblock and boleh kasi at least 600W, ataupun cari 2ch amp yg boleh bridge mono jadi 600W at 4ohm.
mr_maverix
107
mohawk red pakai 200W RMS bro..u can use ur hunter amp to bang them..bridge the amp and test and see for results..jz play along wit the amps settings and see if ur satisfied or not.. :)
ICE_addict
20
i heard monoblok jenis earthquake boleh pukul itu woofer double coil betul ke?
Zenn
2,799
43
1,648
if the earthquake amp is stable down to 1ohm and can give out at least 600W @ 1ohm can la, since u are using 2 units dvc subs.
on the other hand any amp that can give u 600W @ 4ohm also can, u just have to wire the voicecoils in parallel and the subs in series. (instead of wiring in parallel to get 1ohm as above)
ICE_addict
20
thank u zenn....u ade bukak kedai aksesori ke???so hebat one u nie...:D
Zenn
2,799
43
1,648
takde le, sebab minat, belajar sendiri le, mula-2 je complicated.....lepas tu ok...
kedai sendiri takdak tapi keje kedai org pernah le ....tapi insyaallah coming soon.....
ICE_addict
20
adusss...zenn...sori la aku ingat ko chinesse...sekali ade insyallah la...masalah aku sebenarnya susah nak cari brg audio yg bebetul cun untuk kete aku...aku gie kedai kat bangi...dia recommend mono jenis earthquake...website dia www.earthquakesound.com...pastu dia kata masuk pre amp mtx...skang nie aku pakai pre amp caliber...dan aku ade electronic crossover jenis Qmobile...so ape pendapat ko...???ko keje area mana and nama kedai ko keje tu ape...bukan senang nak dapat kawan power audio nie...
Zenn
2,799
43
1,648
aku dah takde keje kedai audio lagi dah......tapi kalau nak dtg join melepak, try la dtg ampang tiap friday night kat taman dagang.....ada sorang lagi pun dari bangi gak, tapi jarang dtg sebab baru dapat baby. kalau nak contact dia aku boleh PM nombor.
earthquake tu apa model? aku boleh cek specs dia tgk cukup power ke tak...
cacin
1,000
5
5,138
Penang
OT:
Zenn, when open shop, don't forget to inform me :P
Bro ICE_addict,
Please make sure the MTX pre-amp the shop recommends is a genuine one. I've seen an MTX pre-amp that does not exists on MTX website....
Another thing is what is your HU? need to know whether the pre-amp is really needed or not. Later you waste money on something that you don't actually need and it's a fake product :P
Zenn
2,799
43
1,648
cheh cacin tanya macam la dok kat KL, haha.....
Zenn
2,799
43
1,648
haha ye la ye la, kang dah nak bukak aku buat kau jadik guest of honor...
ICE_addict
20
alamak...sorry le lama tak bukak forum nie...bro zenn ngan bro cacin,disebabkan nak kecikkan bajet...nie spec audio saya...speaker blakang,pintu,tweter ngan bawah air cond mtx...tak tau ori ke tak tapi ade sticker hologram ntc...distributor mtx...amp lak diamond 800watt,epsilon 800watt ngan mono carspec...h.u lak pioneer 8250...electronic crossover q mobile...sorri zenn tak banyak bajet le...amik yg cikai punye aje...hehe
Zenn
2,799
43
1,648
8250 tu bukan dah ada inbuilt xover ke? takyah pakai qmobile tu, signal kualiti jatuh....direct dari HU ke amp je...
ICE_addict
20
kalau direct dari HU ke amp takyah pakai pre amp ke???cina aksesori tu kate kalau pakai lebih dari satu amp kene pakai pre amp...kalau buat direct ke HU kene tambah ape ape lagi ke bro...???gambar barang audio saya ade kat [email protected] tu bukan 8250 la...silap kot...sebab ade mosfet aje...mosfet tu xover ke...bro zenn kalau mintak tlg bro setting boleh ke...???heheheh
Zenn
2,799
43
1,648
ko kena check berapa rca output belakang HU tu, and kalau ada inbuilt crossover dalam HU. since 8series aku ingat dah ada, so ko cek la apa model HU tu.
kalau takde 2 or 3 rca output, kena la pakai elec. xover
Dear all Senior,
Good day to all of you,
Anyone can recommend me, which shop know how to exchange Wira engine to Mitsubishi engine very well.
I got one VR4 2.0 Turbo engine, thinking to find a workshop to do this engine changing......
Area in Petaling Jaya, Damansara.
Thanks for your kind info~ pls reply my post if u know~
