Hi bros n sis,
Helping my friends to clear their stuffs.
R.E Motorwerkz for pic and detail
Price neg slightly
SAFC 1 - $200
D16 Supercharger kit engine:$6000 with swop
oversize low com semi-forge pistons
low com cometic casket
Eagle conrod
Block pin
PnP head
ARP head stud
ACL bearing full set
ACT 6pad clutch
Kazz LSD
3,4,5 lose ratio
3 inch radiator
Super sprint exo
B18C5 with full type-R spec--$1500-3month old.
EG/EK front strut Bar -- $60
Spoon 4-2-1 manifold and mid pipe-unused-for FD-(LTA friendly)-$2500
Eg sohc final drive 4.0 --$380( good for turbo and supercharger)
Turbo return oil pipe--$100--Steel braided
voltage stab--$60
Blackface tachmeter--$20--52mm
MOMO steering wheel--$150
Fizz turbo timer--$40--used
Dc2 radiator--$200--new
Evo 9 Fmic--$300--spray black--used
B18 low compression piston--$200(used)
B/D series-Die-cast iron turbo manifold--$350(new)
Autoguage meter--$100 for 3meter-VOLT,Vacuum,oil press(used)
TDO6--$800(used)
ESI low compression forged piston 75mm--$200(used 6mth)
VENOM Intake manifold (70mm dia)-- $600 only 2pcs in spore.(used)
Oil cooler 9roll full kit-- $260 (new)
B.O.V---$150(new)
Fuel regulator--$120(New)
Oil catch tank--$80(new)
PM for pic
ALL THE ABOVE PRICE IS IN SINGAPORE DOLLAR.
Thank you
Kelvin-90741002
Price neg slightly
SAFC 1 - $200
Eagle conrod
Block pin
PnP head
ARP head stud
ACT 6pad clutch
Kazz LSD
3,4,5 lose ratio
3 inch radiator
Super sprint exo
voltage stab--$60
TDO6--$800(used)
B.O.V---$150(new)
PM for pic
Thank you
Kelvin-90741002
