ENGINE OIL ADDITIVES engine oil treatment
lucas pure synthetic oil stabilizer is perfect for use in new equipment that requires synthetic oils or any equiment that needs enhanced performance.it's the perfect addition to race car,new car and four cylinder cars
control heat wear in motorcycles,engine and all drive train component
Lucas Oil Stabilizer is a 100% petroleum product formulated to eliminate dry starts and reduce friction, heat and wear. It allows motor oils a higher degree of lubricity which reduces oil consumption and operating temperatures. Use Lucas Oil Stabilizer in gear oil to stop leaks, reduce operating temperatures and increase the life of the gear oil. Since it is pure petroleum, it can safely blend with all other automotive lubricants, even synthetics, ATF and mineral oil. It keeps old engines alive and new engines new.
Lucas pure synthetic Oil Stabilizer is the number one pure synthetic and high performance oil supplement. It eliminates dry starts and resists thermal breakdown for total protection in new engines. It stops smoking, knocking, and oil consumption in worn engines and adds lubricity for more mile per gallon. It lowers oil temperatures and stops leaks. Use it in any manual transmission or differential to stop wear, leaks, heat, noise and hard shifting. Will not void new car warranties. Since it is pure petroleum, it safely blends with all petroleum products, including synthetics.
* Increase oil life at least 50% longer
* Reduces oil consumption
* Eliminates dry starts
* Raises oil pressure
* Increases power and miles per gallon
In engines, use approximately 20% alongside and motor oil, petroleum based or synthetic.
In badly worn engines, use more - up to 60-80% as necessary.
In manual transmissions use 25-50%.
In differentials use 50-100%.
In transfer cases use 25-50% for preventative maintenance and less power drain. If necessary use 50-100% to stop leaks and overheating
one bottle have 956ml
