LSD gearbox
sentro
32
can i know what is difference between normal gearbox and LSD gearbox ?
there are some like semi lsd as well ...
whats the different atcually ?/ smoother ??
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
LSD gearbox, as it says, has LSD unit inside... LSD stands for limited slip differential... it allows only limited slip between left/right tyre to spin at different speed.... this allows better corner exit and greater traction.... FR cars mostly use it to drift......
LSD divided to many types.... 2way, 1.5way, 1way, bla bla bla.... this numbers reflects to how much slip is allowed between left n right tyres...
sentro
32
actually how does slip in lsd gearbox work .. as i know slip mean ur engine wont die if in idle, u engage gear n lepas clutch ...
for normal driving how lsd good ? better power ?
ProTiara
136
Shah Alam
can anyone explain me the detail about the 2 way,1.5 way and 1 way...... differential?i know the number only but i dunno how it means actually (knew since play Grand Turismo 2) heheehehe...
huakenny
LB Performance
9,126
240
3,163
Kota Kinabalu
car with no LSD, left tyre go in mud. then right tyre will not turn/spin, only left tyre will turn as it less load. so ur car will stuck in mud.
car with lsd, left n right tyre oso can turn, so left tyre in mud...right tyre still will turn.
car without lsd power it deliver to either one of the wheel, u jack up ur car n engage gear....u hold left tire n it will stop,but right tire will turn.
car with lsd, 2 tires oso will turn.
Now a days one of the most popular car modification is modifying its back part with a new set of exhaust system.The addition of sports muffler or installing an entirely new exhaust system surely have some performance benefits however I will restrict myself only to the "appearance" benefits.New exhaust system sure have some big bores so you will need to cut the part of rear bumper in order for the muffler to properly fit.Extra care is needed when the rear bumper is quite thin.
Since the...
