now u running ori config? ur hoses i mean.my actuator is 1.3 bar any chance i can modify it back to 0.8 ? i got boost cut now my boost controller got stolen
Also check ur hose if they using a metal nipple to the actuator these piece create high boost.
guys i bought this car the actuator has been modify by previous owner it use to boost high.. i actually got a sard boost controller to lower it down to 0.8 bar... now boost controller got stolen the car not sure boost at how many bar as my apexi boost meter got stolen as well... my foreman said that the actuator need to change or get a boost controller ... i wander is evo 123 actuator can use ?
thank you for all the sifu lesson.. seriously i know nothing shit about turbo car ... most of my time is na.... but thanks again on the advise... like metal nipple not sure wat that mean ? i dun even know how the actuator look like heheh
err... bro.if u using stock actuator i think it wont go to 1.3.maybe actuator out
another thing,if the actuator spring rate is 1.3 bar theres no way u can lower it by boost controller.
if u said it boost higher after your boost controller stolen then most probably the vaccum hose leading to the actuator from ic piping leaking,come off,etc.check that 1st
