Lancer/inspira parts
mfa_145
AMPANG SELANGOR
1. IMP (Improve) REAR ONLY 1 pair sport spring RM 100 - used 9/10
2. Original Inspira CVT cooler RM 100 - used 9/10
3. Original Inspira 2.0P arm rest RM 100 - used 9/10
4. Original air filter element RM 100 - used 9/10 - SOLD
5. Original ATE 2WD ABS pump RM 600 - used 9/10
6. Original Inspira fog lamp 1 piece only RM 150 - used 9/10 - SOLD
7. NEW ISC nitrogen gas filled absorber REAR ONLY 1 pair (OEM replacement, not coilover/adjustable) RM 350 - new 10/10
8. Original Inspira front absorber link RM 250 - used 9/10
9. Original Inspira front absorber mounting RM 250 - used 9/10
10. Original Everco Sunway Top Cat Tri-Flow muffler (al steel muffler painted hi-temp black paint) RM 300 - used 9/10
11. Original single pot caliper (mileage 48k km) + VTTR slotted & cross drilled rotor (got minor hairline crack at the one of the drilled holes (outer side, centre hole of each line), still useable, no vibration at high speed braking i.e. 220km/h) + Trestor brake pads (80-90%) - RM350 (+ free original front disc rotor mileage below 5k km) - reason for sale: ugraded to Nissan Sumitomo R34 GTT 4pot calipers
A Post Every 5 Mins
Hello guys,
Wanna enquire a bit from sifus.
Where would be the most practical and accurate place to mount oil temp and oil pressure sensors for VR4? Will it be accurate enough if I were to get the oil press/temp adaptor which is placed in between the engine block and oil filter? Also any issues with oil leaks for those who are using this type of adaptor? Thanks in advance :)
