Jasma Racing Camshaft for 4G93T
PandaMotorSport
Nov 24, 2012
1,890
638
Description:
  • JASMA high performance camshafts are designed to optimize torque and horsepower over the widest possible power band. Each camshaft application is offered in multiple profiles, each with their own lift & duration characteristics to suit various levels of tuning. Lower profiles offer substantial gains in power and a broad useable power band with little compromise in drivability. Higher profiles offer greater increases in power, but are tailored for the higher RPM range and racing applications.
  • JASMA camshafts are machined from new cores which are constructed from a high nickel content iron alloy. By manufacturing all camshafts from new cores, JASMA are able to produce camshafts that are equal or exceed the quality of the OEM units that they are designed to replace. JASMA camshafts are direct replacements (Plug and Play) and are designed to be compatible with the factory valve train components.
SPECIFICATIONS :
Duration @ 0.1mm Valve Lift : Intake 270 Deg. Exhaust 260 Deg.
Duration @ 1.0mm Valve Lift : Intake 224 Deg. Exhaust 215 Deg.
Valve Lift @ 1.7 to 1 : Intake 10mm Exhaust 10mm
Centerline @ Full Lift : Intake 108 Exhaust 111
For more info pls contact Panda Motorsport at:
Office: 603-56117172
HP: 019-2931222
Email: [email protected]
Our Address:
1st Floor, No.30, Jalan PJS 11/14,
Bandar Sunway 46150
Selangor
Presenting the all new Jeep Wrangler 2011, one of the most capable off-roaders since its inception 60 years ago. This Unlimited Sahara model is able to climb up the rock in a breeze. What's more to love heritage? Enjoy this short video clip of the Jeep crawling up rocks.
YouTube - ‪2011 Jeep Wrangler - "Rock Climber" Commercial‬‏
