how 2 handle squeeky noise in da car esp from da board in a hatch satria
gti[GSR]
791
anyone faced sucha prob? our speakers board at our rear, makin all dis noises... or issit comin from other places? like our rear hood? da plastic panels? anybody?
can give me any solutions?
acidfreako
5
kinrara
wat kinda noises ? mine has this 'tak tak' sound from time to time when i speed and run over some bumpy roads.
gti[GSR]
791
tak tak, ngek ngek, confirm not suspension...
sounds like panel loose... i dunno... u noe those hanging noisy, scraping noisy... something loose noise... hard to explain...
but is dere nay solution to these?
gti[GSR]
791
yea me 2...!! anybody hav solution ar? does da car sound dampening thingy works 100 percent? coz im gettin annoyed big time wif those noise ey... how how? sifus? master???
S1997
1,001
for my case, the two sockets (left and right) that hold on to the board were causing the krek kre sound.
so i took out the board, put some paper inside the sockets, so squeezed the points that were supposed to be attached to the sockets in. So the paper tighten the gap lar...Sound disappeared after that.
gti[GSR]
791
sounds gud advice i'll try later dudzz. thanks... if anyone still got opinion den it'll b gud :)
ealt
2,395
16
it came from back cover n glass.There is a gap between it.That is the main reason, noise happen.put some rubber between it...good luck
gti[GSR]
791
u mean da board? yea i noe da board has a thingy dat pushes da glass... but if i removed da thingy, denit wun even touch da glass... so y is dere noise still? keeps me wonder??? any more??? hmm more options da better ways to handle dis annoying shit man
S1997
1,001
suddenly thought of something
any stuff loose in the spare tyre compartment?
ealt
2,395
16
I put some sound proofing material inside the board.First, take out the rear board and put the material at both side of board n body.Glue on it.Works on me.Now I can have a nice sleep.cheers.
Dique
1,178
home
is tat the noise coming from da back speaker board? it's common for hatch back car!
if yes, when u open ur trunk, da board will lift up at 1 side rite. another side is remain there, there's a supporting rod underneath, jst try to put some oil or WD40 where it contact with da plastic....hope will help!
gti[GSR]
791
oh realli? hmm sounds possible... wellz bout da sound profin material, where did u get it done? where can i get it done 2?
ealt
2,395
16
I bought it from ninja_iga.Install it myself.very simple.you should try it.
ealt
2,395
16
gti[GSR]
791
hmmm ealt bro, wat to get? how 2 install? how to open up our boots, where to stick dem? how how?
i tried puttin wd40, n it didnt work, ir eckon its comin from da panels ey... sigh... so i hoe dis wat u suggests thingy willw ork ey...
gti[GSR]
791
wellz, i jus tried sticked some sponge 2 da plastic cover of mha bonet at da rear... reduced da noise... but stil got other sound ocmin out
Like your engine oil, maintaining your transmission fluid is equally as important, even more so for automatic transmissions. Manual gearboxes do not have oil pumps and the oil is stagnant and is just there for lubrication purposes. To maintain a manual transmission is a straightforward process - drain the old oil, pour in new oil and that's it.
For auto trannies, it's a little different. There are generally...​
