Honda Civic EK Track Car For Sale.
These Track Car are setup to compete in RACE CAR CATEGORY CLASS 2(RC2)-1900cc below.(Saturday nite fever challenge series-SNF)
221whp
187 N.m (Torque)
Fuel type: Petronas AV Gas Ron 100
Specification:
A: Engine Specification
1-Custom air cold intake
2-S90 Throttle body 70mm
3-B18C Type R (Port & polish Intake Manifold
4-Fuel Injector -Injector GSR turbo (MITSUBISHI)
B: Head
1-Port & Polish Head
2- Cam Skunk 2 Tuner 3
3- Adjustable campulley
4-Skunk 2 Valve Spring & retainer
5-ARP Head Stud
7-Gates Racing Timing Belt
C: Block B18C Type R
1-Supertech Piston 83mm
2-Type R Condrod
3-Original Engine Bearing
4-Engine Full Balancing
5-Orbit Oil Pump
6-Custom Oil Sump
7-Oil Cooler (TRUST Greedy)
D: Gearbox
1-Clutch Plate Competition Clutch
2-Gear Ratio- KAAZ 3,4 & 5
3-Final Drive 4.4
6-Full lock KAAZ
7-Steel braided Hose Clucth Pump
E: Electronic
1- New WORKS Meter-Oil Temperature/Oil Pressure/Water Temperature
2-MSD SCI PLUS-Complete with amplifier/switch rev limiter/ignition retard/cap distributor and cable
3- Killer switch (internal & external)
4- HID
ECU- HONDATA V2 with new converter harness
F: Exhaust System
1- Xtractor Hi Tech (PLM)
2- Custom Muffler
G: Brake System
1-Front-CL1 EURO R Caliper
Rear-EK4 Caliper
2-Rotor Disc- Slotted Disc(Front & Rear)
3- Front Brake Pad- Endless 500 degree
4-FEEL'S- Steel Braided Hose (Front & Rear)
H: Fuel System
1- External Fuel Pump BOSCH
2-Surge Tank ARC
I: Suspension
1-Buddy club(body shift/ (Hi/Lo soft hard/ pillow bowl)
J: Chasis
1- Additional Spot Welding for all chasis to strengthen the chasis
2-Complete camber kit (Front & Rear) HARD RACE brand
3- Custom bush (PU) all including: camber kit/mounting engine/ front & rear(upper & lower arm),gear linkage bush
K:Interior
1-Fully strip and weight reduction inside car
2-1kg Fire extinguisher
3-Roll cage 6 point -Stand 21
4-All Prospec Plastic screen (except front windscreen use glass )
L: Exterior
1- Carbon Fiber Front Bonet
2- Fiber Glass material -Front side Fender
3- New Paint 2K solid white
M: Tire & Rim
1- Toyo Proxes R888 (45%left)
2- Rims- TE37(taiwan made)
These car have no document and cannot be on the road, is only for Track use.
Selling Price RM30,000.00(nego)
For more detail pls call/whatsupp
Faiz 012-619 5073
221whp
187 N.m (Torque)
Specification:
B: Head
5-ARP Head Stud
2-Type R Condrod
5-Orbit Oil Pump
6-Custom Oil Sump
D: Gearbox
3-Final Drive 4.4
6-Full lock KAAZ
E: Electronic
4- HID
F: Exhaust System
2- Custom Muffler
G: Brake System
Rear-EK4 Caliper
H: Fuel System
2-Surge Tank ARC
I: Suspension
J: Chasis
K:Interior
L: Exterior
M: Tire & Rim
Faiz 012-619 5073
