HKS Circle Earth Grounding Kit
youmolo
208
Subang Perdana
www.tzywen.com
does grounding kits really improve throttle response? i've heard that installing grounding kits can give better power. I think that's true for older cars only with very corroded chassis...
drexchan
2,908
100
3,163
Bukit Jalil
drexchan.fotopic.net
No, won't improve throttle response.
Better power? Most likely the LOST power is being regained. You are right about the aged connections. But it works on new cars too. Those that doesn't has sufficient grounding in the factory setup - that's almost every japanese-base car.
satria_95
6,000 RPM
6,746
18
5,138
Malaysia
I somehow doubt that grounding will provide any improvements in performance but I could be wrong. Even if it did, it'll be rather minimal. I would opt to think of installing grounding if it helps to stabilize or prolong the life span of anything that's electrical, or something like that.
c-ground
311
3,016
Seri Kembangan
cground.fotopic.net
Yes, you are particularly right. We have emphasized it for more than 1 time.
youmolo
208
Subang Perdana
www.tzywen.com
japanese based cars have poor grounding? what's the story behind that?
daze
168
KL<>JB
Any recommended VS+GK ? How much and where to get it?
Around JB? saw some GK in some accessories shop. very thick cable. nice cable wrap but dunno how reliable compare to a good one?
Saw in ZTH there's one Votech brand, how was it? Hows d pivot brand then?
c-ground
311
3,016
Seri Kembangan
cground.fotopic.net
----> c-ground <------??
Anyway, we only do grounding cables. If you are looking for VS, you may want to try Votech or khguan's DIY.
c-ground is compatible to any VS since we can customize the layout for a specific car model.
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
In my own knowledge,
Volt Stabilizer is used to decrease fluctuation in electric current which mean more stable current flow.
Earth Cable is used to smoothen the flow of electric current...
Inside the VS there are big condenser that stores current for a short period of time then release it. i think this is how they control the fluctuation of the current...
mp5onfire
39
penang
drexchan said:
not condenser.. capacitors lar..
not just one.. a series of different caps with different capacitance value..
ermm... condenser and capacitors r the same... just a diffrent name
eye
15
Butterworth
can we feel any changes if we install it??
some ppl say that we can feel become lighten when we 'lajak', is it true??
salam to all brother's....
i'm kind of new in thing's so i want to ask y'all
i want to buy satria gti std / gti convert gsr 2nd, so it is ok to buy ?
what about the feul c, modification and other thing's...
i want use this car as family car also
price is around 25k, yr 98, what do you think?
pleazzz help me......:rolleyes::rolleyes::rolleyes:
