does grounding kits really improve throttle response? i've heard that installing grounding kits can give better power. I think that's true for older cars only with very corroded chassis...
No, won't improve throttle response.youmolo said:does grounding kits really improve throttle response? i've heard that installing grounding kits can give better power. I think that's true for older cars only with very corroded chassis...
Yes, you are particularly right. We have emphasized it for more than 1 time.satria_95 said:I somehow doubt that grounding will provide any improvements in performance but I could be wrong. Even if it did, it'll be rather minimal. I would opt to think of installing grounding if it helps to stabilize or prolong the life span of anything that's electrical, or something like that.
japanese based cars have poor grounding? what's the story behind that?drexchan said:No, won't improve throttle response.
Better power? Most likely the LOST power is being regained. You are right about the aged connections. But it works on new cars too. Those that doesn't has sufficient grounding in the factory setup - that's almost every japanese-base car.
----> c-ground <------??daze said:Any recommended VS+GK ? How much and where to get it?
Around JB? saw some GK in some accessories shop. very thick cable. nice cable wrap but dunno how reliable compare to a good one?
Saw in ZTH there's one Votech brand, how was it? Hows d pivot brand then?
Sorry ya... please be patient.. we also not sure. Time to pick up the phone and kick some butts I think..ChuckY said:aiyah~ c-ground..when stock mari lah~? i wanna do grounding lah~~~~
ermm... condenser and capacitors r the same... just a diffrent namedrexchan said:not condenser.. capacitors lar..
not just one.. a series of different caps with different capacitance value..
