is this waja crankshaft and pistons easily available bro? and do i need to change my management? or is the stock one should be enough for now?
Aiya.. I forgot to take pictures. Basically the pulley looks like this (it has teeth at the 2nd cog)Bro iszo, so got the pic already?
Btw can i simply use the 1.6 piston (korek abit) with stock ecu running it? alang2 since i open the engine head.
81mm on the stock 4G15 block is too thin la. I don't think it'll work without heavy modification to the cylinder walls. The biggest I've seen that's safe is 77mm.nk guna piston 1.6 4g92??? 75.5 nk korek smp 81mm?? msuk stroker kit waja 4g18 :)
Waja crankshaft quite hard to find these days. New is is 2k+ and 2nd hand if you're lucky will be 800. Pistons can just use the BLM campro one 77mm but height is just nice. You'll need to rebore the cylinders and personally I think you should replace the cylinder lining. Keep your conrods.is this waja crankshaft and pistons easily available bro? and do i need to change my management? or is the stock one should be enough for now?
the internals have to be strengthen as well if you plan to supercharge the engine in the future.Bro, seems like alot to do if rebore. Might just save my money to supercharge next time. Alang2 use ecu..
So far, ive managed to get the 421 extractor n 2.0" piping (just to prepare just in case...), camshaft n cam pulley, aluminium radiator (for the looks), diy cold air intake, bosch 4 spark plug, properly check everything...
Next is to source the crankpulley as mentioned by bro iszo...
N tbh ive spent well, below my expected budget (lets just say all these items equals to my ex yaris trd short shifter n pulley only, from japan of coz.)
With all these, can I expect any gain? Can play w stock vios? Aha I know for sure weight of satria n vios almost the same.
Tq bro. but for now, i want to see the progress of the hp gain. if it can play with vios or those 1.5 engine, I am going to slow down for a bit and will continue next year for supercharging and maybe a standalone, or maybe i dont have to do it if i am satisfied with the gain so farthe internals have to be strengthen as well if you plan to supercharge the engine in the future.
Bro, stroke + oversize pistons + cams, PNP, balanced and a 3-speed auto wira aeroback and keepup with a Vios easily. Only problem is top speed, 3-speed auto gear ratio not long enough. Too long and you lose pickup.Tq bro. but for now, i want to see the progress of the hp gain. if it can play with vios or those 1.5 engine, I am going to slow down for a bit and will continue next year for supercharging and maybe a standalone, or maybe i dont have to do it if i am satisfied with the gain so far
As for my plan now, i dont intend to use oversize pistons or crankshaft yet bro, not this year. I found 1.8 manual gearbox in Miri. Dont know whether it will fit or not, going to search/ lighten flywheel and get a good set of clutch kit. hope the ratio will be better in terms of the top speed issue or maybe RSM to open the rev cut and speed limitBro, stroke + oversize pistons + cams, PNP, balanced and a 3-speed auto wira aeroback and keepup with a Vios easily. Only problem is top speed, 3-speed auto gear ratio not long enough. Too long and you lose pickup.
Imagine what a satria manual can do with a lighter body!
I want a 1.8 gearbox. My current 1.5 manual ratios are too short. But if I can find the budget, I wanna change the final gear ratio.
Btw, I think cost wise stroke/oversize/pnp/lighten/balance vs supercharge, I think price wise they are very similar. But the SC will give you bigger gains I think. But imagine if you had the stroke and all done before supercharging.
POWAAAAAAAAAAAAAAHHH
blh..piston n crankshaft 4g18...brand jasma pon ade...conrod asl 4g15nak gune piston 4g18 boleh ke bro? atau ade ke stroker kit 4g18?
tq bro :)blh..piston n crankshaft 4g18...brand jasma pon ade...conrod asl 4g15
Mind sharing what sort of pistons and crankshaft you recommend bro? those easy to get pistons? how bout Jasma crankshaft?
Bro i feel you there. hope you find your budget soon. Ive read somewhere in Zth before, modding is money, and money is not easy to get thats why it took me months, wait.. years of savings, prioritizing other stuffs and save only bit by bit for my car. good thing is that ive driven the sluggish satria for years, and i hope i can feel the differences with these loads of stuffs and mods to come... will update it bit by bit here
Pistons are very easily purchased at spare parts shops. I was quoted RM160 for a set of 4 BLM pistons. Oh mah! Jasma crankshaft not the same as Waja 1.8. The stroke difference is about 0.7mm so Waja crank more powaaaaaaaaaaahh (actually more stroke la). All depends on what it is you want. Some say shorter stroke faster rpm buildup, some say longer stroke higher horsepower. I dunno. It's all up to your own research.Owh yea, and one more thing, i think i need a new speedo (probably wira SE's speedo) and some interior part such as gti gear console?
tq bro :)
