Acoustic has finally convinced me to design(more like copy and then adapt the idea, haha) custom build and produce :
rear trailing arms / rear four links
here's how it would look like, (from technotoytuning.com)
and Panhard rod/ lateral rod
(pic from technotoytuning.com)
anyways, here's how we're gonna do this.
i need a minimum order of : 3-5 Hachirokus/ similar platform
the parts:
2 long trailing arm tubing
2 short trailing arm tubing
1 Panhard rod tubing
5 M14 (14mm) left thread rod-ends
5 M14 right thread rod ends
10 stainless steel nuts
20+ brass/aluminium spacers
zinc plated M12 bolts (unknown figure)
this is what we call a rod-end (spherical ball-bearing joint)
the tubing are seamless tubing carbon steel 3.4mm thick, 25.4(1") outer diameter(O/D). The ends are weld with turned and tapped rods to screw in the rod-ends. The rods are welded to the tubing.
finishing can be powder-coated (can be primary colors) or hard-chrome plated.
The tubing also has a machined flat area to accept a wrench for adjusting purposes.
Price for this new toy is in the sub RM1000 region.. :blink:
costs for materials ALONE is RM700+ liaw..
not including machining, finishing + some profit margin..(let me earn la, i'm doing the work ma...)
anyways, WHY THE HECK DO i NEED ONE of these ???!?
here's why:
Panhard Rod
SO?? why shouldn't i just BUY it off from technotoytuning.com instead from you!?!
-simple. Costs. technotoytuning is selling the entire set for : USD$449 / RM1750+
not inclusive of shipping too.
okie,
here's the 'victims' list :lol: :
1)Acoustic sifu
2)sideways syndrome sifu (MK84!!)
3)??
4)??
5)??
the parts:
here's why:
Panhard Rod
Trailing ArmsThis rod has enough adjustability to be used on a stock height car or a car that is drastically lowered. Even on our test mule car (which hasn't had any of the other suspension modified), it made a drastic improvement in handling. The REAR END WIGGLE is GONE!
(qoutes from technotoytuning.com)Also known as rear trailing arms, our Rear Four Links feature Heim joints (Spherical Rod Ends) at both ends! Zero Slop, and Zero Deflection. Eliminates Axle hop during acceleration and deceleration. Greatly improves to the ground traction and driver feedback. Traction is greatly improved (all the power gets to the ground without any wheel hop) and it is easier to break the rear end loose by "throttle on" even in wider drifting corners. Makes it a lot easier to control a drift with just the gas pedal. The whole rear end is super tight and not sloppy at all since there is no longer any diagonal movement of rear axle. Zero twist of the rear axle also. Every throttle input goes right to the ground.
okie,
1)Acoustic sifu
3)??
4)??
5)??
