- Sep 20, 2004
- 265
- 0
- 3,016
im using the aftermarket headlamp for my honda.....the problem now is with it fuse....this problem didnt occur last time....the fuse code for the headlamp is 15.the fuse got "burn" last two days....so i replace it with the same fuse code that is 15.when i swicth on my headlamp the lamp didnt turn on....so i check back the fuse...and the fuse already"burn".is there any wiring problem fo my car???or i just have to use other fuse code???i mean the fuse that can hold a bigger electric resistance????and if yes what is the suitable code for it???any suggestion???i become more confuse because this problem just occur now since im using the headlamp for about 2 years already.
