Fuel Management Unit
kenken
931
Ipoh
Anyone sifu here heard of Fuel Management Unit(FMU)? its work likes a fuel regulator but it increases fuel pressure only when theres positive pressure in the manifold at certain ratio.(eg. 12:1 , 12psi of fuel pressure increase at every 1psi of boost)
another type is the rising rate fuel regulator. its adjustable and works like FMU too.
anyone knows this FMU thingy? is it good? how much is it? and where can get?
fks123
69
hey there...
i am not sure if this is of any help...
do check this out... http://www.ps-powersport.com/product_FFS-313c.asp
Dragger Racing have them .. but be reminded its not cheap...
i wanted to have this in my BOT but eventually settled for Walbro fuel pump and adj fuel regulator... because its cheaper..
kenken
931
Ipoh
no bro..its nt tht. its something that increase fuel pressure by blocking the fuel return line when boost is detect (via a vacuum hose frm manifold to the FMU)..
so its different. it comes in a few settings. 12:1psi, 10:1psi,8:1psi and so on..
kenken
931
Ipoh
Fmu
flushafteruse said:
its mechanical or electronic??
Friend, the FMU runs fully mechanical. it has a diaphrapm in it.
go www.vortech.com
u can see that thing.
g88
3,082
54
Am not sure are you referring to his or not
http://www.haltech.com/haltech.htm > click > Fuel Only ECU
Price expect to be Rm800 or above Rm1000
There are many type of after market ECU where some NOT really STANDALONE instead like piggyback....intercept your original ECU (providing that it's compatible)
Hope this help...
kenken
931
Ipoh
sorry fren its not an ecu.the FMu is somethng tht allows NA engine to bolt on turbo or superchargers without changing ECU...
i wonder any shop sells this?
i think i saw this in KSP before..
The Ghedi (Brescia) military airport was the setting this week for an extraordinary acceleration race between a Tornado aircraft [A200-A] provided by the airbase, and the Lamborghini Reventón driven by an official Lamborghini test driver.
The fighter pilot and the Lamborghini test driver challenged each other on the 3000 m-long runway.
The Reventón took the lead in the first...
