Exhaust emitting white smoke.
Nov 9, 2011
Greetings guys,
I'm currently driving a V6 Perdana year 2000, and it has been giving out a lot of white smoke recently. Also I have to keep refilling my engine oil as it runs out quickly. On the other hand, when the engine is cold (eg. In the morning), on start-up the engine produce this clanky sound but the sound soon fades away after the engine is warmed up properly.
As I roughly know, this has something to do with the piston rings or gasket seals (if i'm not wrong). Just would like to hear from the experts here :).
The engine and gearbox was previously overhauled 3 years back (mileage back then was 170k km while current mileage is 275k km). It would suck if I have to overhaul the engine again. What's your 2 cents?
Cheers!
one1002
140
10
i'm having similar problems...the clanky sound you mentioned, does it sounds like tappet or hydraulics lifter sound?it's like "tet tet tet tet tet"..
waiting for other's feedback as well...
YYC
1,833
939
terrytkf,
I am afraid you have to overhaul the engine again because of the worn out piston rings leaking engine oil into combustion chamber and emitting as white smoke. This may explain why you need to top up engine oil frequently.
terrytkf
Yeah I'm not sure what component is related to that sound, a friend of mine said something about the Perdana V6s using autolash? :S
time for top overhaul, u could buy the kit yourself & get your foreman to do it.
Yup, I'll be sending my car in for roughly a week in the next 2 weeks to finally get everything done.
NeuroOne
WFH
2,074
181
Putrajaya
if its the piston rings worn out, u have to do full overhaul, not just top overhaul.
and the sound "tet tet tet" is beocz of the tappet lash adjuster (valve lifter).
this is very common in Mitsubishi.
i've read that the newer generation of valve lifters eliminates the sound but i found those things in Aus or US forums.
just use semi or mineral to minimize the sound.
or check your oil pump (NOT fuel pump) if its working nicely to pump enigne oil to all the engine part including the engine head.
mymax
164
72
just ignore la the tappet sound.. unless it's louder than it shoud be..
without tappet sound it's just like watching the video clip without music.. :biggrin:
Similar threads   Forum
  Similar Threads
The Nissan GT-R has been killing it on almost every type of racing it has entered, be it circuit, road rallies and even drag racing. Now however, the GT-R has been bestowed the true drag racing treatment as the interwebs are chirping with news that ITP Racecars in Perth, Australia, has been working on a trio of funny car style GT-R drag racers...
