engine sebu/jerking at 3-4rpm..
May 5, 2014
i have a honda civic so4 with d16a non vtec inside..auto transmission..
-recently my car is having jerking problem at 3-4rpm..firstly i suspected it might be missfire problem.so i replaced new plug cable,spark plug,distributor cap..but the problem remains,i even swap another distributor as well as ecu,but it still remains.
-later i tried to use ron97 fuel and the jerking problem gone.but after 3days it started to happens again.fuel consumption also bad..full tank of ron97 only able to get 350km.
-rpm idling is just ok..maintain on 900rpm..but when moving,it will jerk at 3k-4k rpm..when cruising,the jerk will happen sometimes.
-so now im suspecting the fuel mechanical is in fault..either the throttle body,fuel filter,or injector?
pleasee help me..:banghead::mad:
The legendary Quattro all-wheel drive system has found itself under the chassis of most of the rapidly expanding Audi range with one major exception, the nimble A1, that is sadly only available with motivation to its front...
