Engine Block Overhaul !
D7zul
2,697
848
Shah Alam
engine block or total engine overhaul?
if only engine block, u can rebore.. just bring to foundry shop that have the machine..
if engine overhaul, need to grind valve, check if there's any abnormality on the engine head, piston ring etc..
Gudluck :burnout:
mines998
1,048
149
663
DanzEterna said:
the only thing u could do to the block is skimm & rebore it...
Both also need highly skill if anything wrong you will have big problem.
protonevo
247
Selangor
www.zerotohundred.com
Well already sent my car for ICU ! the entire engine dismantle and change all worn parts. So decided to change Mivec piston and port and polish. Will update my total damage when is done on next week. Cross my finger to hope everything will go fine during Dyno.
BE5RSK
343
125
Besaout
Sound like fully engine rebuild.
since the entire engine fully dismantled, perhaps you might want to change the engine bearing, check/replace the rods to stronger one, balance/counterweight the engine crankshaft, and change the engine studs to stronger one.
Do it once, and do it right (and completely) :biggrin:
mines998
1,048
149
663
Ya I agree make it right at 1 time. We not sure how is the engine condition before you go for full overhaul so it much depend yr pomen advice. Re-build engine not everyone can do it because it need experiance & skill to it.
protonevo
247
Selangor
Finally get back my car on yesterday after 1 month wait. Well still worth it ! total cost 4K+
- Port and Polish engine head
- Mivec 81mm piston
- KING bearing
- All others oil seals and gasket
Worth It !
Newbie here,
i have a Ride tat is Suzuki Grand Vitara 2000 equiped wif 2.0 diesel and intercooler turbo,
is it possible for me to add a blow to my ride?
any comments, suggestions, advices to my ride, please to tell me.. thx !!:shades_smile:
