Over Boost - Motorsports
Beyond 20,000 RPM!
![dpsema.jpg](http://www.overboost-motorsports.com/dpsema.jpg)
DRIFT PERFORMANCE TURBO HEADER AND EXHAUST MANIFOLD
- Available in polished stainless steel only with excellent durability
- All drift performance manifolds are exhaustedly tested to ensure durability, quality and high power output
- High quality mandrel bend design to ensure less turbulence which helps maintain boost pressure at higher RPM
- All exhaust manifolds are made of highest quality T304 Stainless Steel material
- High quality thick flange which are laser cut and metal gaskets to prevent leaks
- No grinding done on welded in collectors to prevent high possibility of cracking and debris damaging the turbine fins
- 2 mm piping thickness for durability with different piping size according to make for best result output
- Designed to allow turbine to spin at lower speeds creating equivalent boost
- Drift performance exhaust manifolds allows hot exhaust gases to expand without reducing flow and prevent backpressure
- All welding is high quality TIG welding for maximum durability to prevent cracking
- Plug and play and comes complete with gasket and bolts
- Reduces turbo lags providing early boost response and torque with highly increase top end horsepower
- Highly recommended to change together with turbo outlet dump pipe and extension front down pipe with cat back system
- 1 year warranty on manufacturing defects
- Made in Australia
PRICE
NISSAN SILVIA SR20DET
Nissan Silvia SR20DET T25/T28 Turbo Flange (42.7mm diameter pipe) - RM 1,499
Nissan Silvia SR20DET Tuned Lenght Runners T25/T28 Turbo Flange (42.7mm diameter pipe) - RM 1,899
SUBARU IMPREZA / WRX EJ20T WITH UP-PIPE AND SLIP-JOINT BRACKETS
Subaru Impreza EJ20T Year 95-99 (60.1mm diameter up-pipe) (42.7mm diameter pipe) - RM 2,499
Subaru WRX EJ20T Year 2000 on (60.1mm diameter up-pipe) (42.7mm diameter pipe) - RM 2,499
NISSAN SKYLINE R33 / R34 RB25DET
Nissan Skyline RB25DET T4 Turbo Flange With External Wastegate (42.7mm diameter pipe) - RM 2,299
NISSAN FAIRLADY 350Z VQ35DE
Nissan Fairlady 350Z VQ35DE Tuned Lenght (42.7mm diameter pipe) - RM 1,999
MITSUBISHI LANCER EVOLUTION 4-9
Mitsubishi Lancer Evolution 4-6 4G63T Twin Scroll TD05 Turbo Flange (45mm diameter pipe) - RM 1,999
Mitsubishi Lancer Evolution 7-8 4G63T Twin Scroll TD05 Turbo Flange (45mm diameter pipe) - RM 1,999
Over Boost - Motorsports are the one and only Authorized Distributor and Authorized Import Agent for Drift Performance Products
![zthlogo.gif](http://www.overboost-motorsports.com/zthlogo.gif)
CONTACT DETAILS
Address - No 28A, First Floor, Jalan PJS 11/7, Bandar Sunway, 46150, Petaling Jaya, Selangor, Malaysia (same row as N1 Racing, beside WRC Lighting)
E-Mail - [COLOR="Black"][email protected][/COLOR]
Tel - +603-5611 6628
Mobile - +6012-955 1800
Blackberry Pin - 2284DEF5
Website - OVER BOOST - MOTORSPORTS
MSN - [COLOR="black"][email protected][/COLOR]
Skype ID - overboost-motorsports
Facebook - Over Boost - Motorsports | Facebook
Mudah - PRO Niaga: Over Boost - Motorsports
CLICK HERE FOR CONTACT FORM
35614_110641625673775_109533879117883_96090_7321984_n.jpg87.6 KB · Views: 1,200
63219_110641832340421_109533879117883_96106_4542639_n.jpg150.2 KB · Views: 108
63266_110641792340425_109533879117883_96103_4466175_n.jpg89.1 KB · Views: 103
63402_110641672340437_109533879117883_96092_4906878_n.jpg136.3 KB · Views: 109
68147_110641585673779_109533879117883_96086_4136796_n.jpg129.1 KB · Views: 104
68562_110641372340467_109533879117883_96070_8214573_n.jpg115.8 KB · Views: 100
69556_110641775673760_109533879117883_96102_4132806_n.jpg98.6 KB · Views: 105
69720_110641535673784_109533879117883_96082_2483174_n.jpg127.8 KB · Views: 101
72016_110641602340444_109533879117883_96088_7405029_n.jpg133 KB · Views: 113
148252_110641809007090_109533879117883_96105_6237652_n.jpg95.1 KB · Views: 103
154154_110641725673765_109533879117883_96096_7238068_n.jpg163.6 KB · Views: 111
154888_110641329007138_109533879117883_96066_5004444_n.jpg137.1 KB · Views: 100
155156_110641515673786_109533879117883_96080_1596415_n.jpg144.5 KB · Views: 118
155519_110641495673788_109533879117883_96079_4080012_n.jpg152.9 KB · Views: 95
156724_110641352340469_109533879117883_96068_1582280_n.jpg139.2 KB · Views: 99
162856_110641695673768_109533879117883_96094_2549332_n.jpg141.2 KB · Views: 105
34801_110641859007085_109533879117883_96108_812233_n.jpg90.3 KB · Views: 109
36274_110641935673744_109533879117883_96114_431574_n.jpg146.2 KB · Views: 92
156863_110641905673747_109533879117883_96111_7200261_n.jpg101.3 KB · Views: 106
