Does old engine mounting causes steering vibrations at high speeds ?
Mar 21, 2008
674
15
Recently I have change my driveshaft and also new tyres, checked balancing, alignment n camber.
But why does my steering vibrates at 120kmh onwards ? Could it be the old engine mounting I havent changed?
btw, I am using adjustable suspensions.
SoYouThinkYouCanDrive
Banned
674
15
nissan sentra.......
PS:True, I hate proton n perodua, thats my preference.
GroundZro
421
Yes, bad/old engine mounting can cause problem. Have have the mounting checked....Bring it back to the place where you replaced the driveshaft and ask them to check...Check your balancing too, just to make sure.
Banned
674
15
thanks for da info :wavey:
Banned
674
15
no, all havent change since i bought the car, only changed driveshaft
arrowhead
4,621
152
5,163
Damansara/PJ
bro, in some very rare cases, which happened to my dad's car awhile ago. also vibrate at 120km/h, was the tire not round. manufacturing defact. u should get it checked.
just sharing my experience. :biggrin:
Escortmaniac
55
Malaysia
Hey there Bro... I've not been comin to tis zth for months... i poped by and saw this... so wanted to share my 2sens.. Engine Mount's Should Not allow ur steering to vibrate at high speeds.... it does not concern the Handling... are you using Sport rims? do u have Spacers? check the Balancing of ur tyres again ...if it doesn't help seek for On-wheel balancing
...and of all simple things ....Check your Tyre pressure....
Escortmaniac
55
Malaysia
Steering rack bush can contribute to the vibration.. but... only when it comes to potholes and uneaven roads... not on highways and highspeeds...
Banned
674
15
Maybe it cud be da cones coz i added 'em to fit my rims
shinrei
57
what cones? my car also vibrate when reach 120 but maybe it is because of my rim(bengkok)..:biggrin:
Escortmaniac
55
Malaysia
well u added those cones.... those cones are specifiedly made to make ur car not vibrate at high speeds..... check on those rims mate...are they new? or got bengkok dee?
qpywsqp
477
hi there. you mention that you been change your driveshaft, so i for sure is your rim bengkok. you try to ask your mechanic to check your wheel balancing (on wheel). because i have same case with you before.
shinrei
57
the cones is for what? never heard of it.. does the cones have a specific name? :driver:
A lot of speculation surrounded the new SL recently, so much so that I refused to write about it till something was confirmed. Didn’t want to portray ourselves as automotive paparazzi. So here is something that has been confirmed: Mercedes has made the SL uglier and slower, though power outputs are standard Benz ratings, that means insanely high torque outputs and modest horsepower, well, by today’s...
