DIY: Question about connections
malwinder
111
melaka
malwinder.20fr.com
hi i am facing a problem....how do u connect a 18 AWG wire to the battery.......do like just lilit over the terminal or pateri it to a metal loop so that it can fit in the screw....?????thanks.......
phat7
2,122
62
i run a direct 12v source to my fuel pump and pretty much know what you;re facing. do not "lilit" it around the battery as this is part of the reason you see cars burning on the side of the road. get a proper connect then crimp the 18awg wire into connector, solder then get heat shrink tubing to ensure proper insulation.
malwinder
111
melaka
malwinder.20fr.com
ok i got a question to ask.....now i got too many wiring bolt on to the battery and the screw is not long enough...i want to change the screw to a longer screw....can i just use any normal screw or got specific screw for battery wan....
malwinder
111
melaka
malwinder.20fr.com
one more question where can i buy the heat shrink tubing and connector......so the end which is bolt onto the battery looks like a ground cable ending lah with a round ring connector and a tube for insulation right......right???
huakenny
LB Performance
9,126
240
3,163
Kota Kinabalu
i got cousin deal wit tis cable lug n heatshrink....let me know the size o snap a photo of ur cable....
if grounding lugs i got la....wire lug i oso got..but not sure ngam u o not..otherwise hv to ask my cousin...
c-ground
311
3,016
Seri Kembangan
cground.fotopic.net
for a neater look.. you may want to join all the wires into a bunch, and then crimp it to a lug of a suitable size. Then heat shrink the few inches from the lug. However, if your wires are not permanent, you can do it separately, then tie them together wioth a cable tie, and then cover them with a cable organizer:
malwinder
111
melaka
malwinder.20fr.com
where can i get the cable organizer ar....i tried a few hardware shop...cannot find.....
today, 11.11.10, as usual every thurs, i will leave my apartment
@ 530am to send my wife & daughter to her parents hse....as i was in the lift heading down,
there were this couple, bout early 40's also together in the lift, they walked ahead of me 1st as i have to detour to the dumpster to throw rubbish. As my other car is usually parked outside the apartment compound, i was carrying my bag & daughter walking out.
When i reached my car, right outside the guard hse, opened the door for...
