Dive and Squat problem?
AnotherX
hi there, anybody know what is wrong when my car dive or squat a lot during acceleration and braking. how to solve ar?
sport spring will reduced this symptom.if u got extra money,u can go for
adjustable.if u don't feel like changing the spring,gas abs will do.
for the meanwhile do not make sudden acceleration and brake slowly with distance will reduce those effects i guess. correct me if i am wrong.
hahaha....yup...that's the cheapest way.no money involved.just change ur
driving technique.
my guess is....just get ur suspension upgraded to some recommended settings for your ride.....
it'll help reduce your braking distance for safety as well as reduce squating when launching...causing less traction....i assume ur ride's a fwd...
happy modding
yo thanks,
another question, do i need to change the whole suspension kit or the spring only?
well if budget permits...a set of dampers and springs of the appropriate setting for your ride...would be good....
if you change only the coil springs....u'll have to go for something which matches ur stock dampers...else....on most occasion a swap of aftermarket coil springs would kill the dampers prematurely....
erm well, there are local suspension fabricators who can service and recond stock dampers...but most of the time it'll cost 80 to 100 bucks to recond a 80 to 100 bucks stock damper...so wat's the point?
happy modding
Which, in the same time increases your brake's life span and also decrease fuel consumption! Good!
