D-Imports TurbochargerS,TD05 20G,T3T4,T70,T25T28
dre42
7,000 RPM
Drego Imports[/size]
STOCK CLEARRANCE !!!
BRAND NEW IN BOX
TD05H -16g ( WATER COOLING )- Mitsubishi EVO ,water cooling , twin fins-16g internal wastegate,
TD05H is twin fins compressor wheel . Flow range is 0.05-0.22 kg/s , work for 50-130kw engine. ( especially for EVO III )
UP TO 350 HORSEPOWER
TURBOCHARGER T3/T4 STAGE III WHEEL BRAND NEW RM1200
Uploaded with ImageShack.us
1/8 NPT OIL INLET T3 / T4 FLANGE
FITS T3 AND T3/T4 MANIFOLDS SPECS:
. 50 A/R COMPRESSOR .63 A/R TURBINE.57 TRIM
THIS TURBO CAN EASILY DO 25 psi
Standard T3 Flange,
TURBINE WHEEL:
EXDUCER: 2.48"
MAYOR : 2.89"
COMPRESSOR WHEEL :
EXDUCER: 2.07"
MAYOR : 2.36"
5 BOLT FLANGE SUITS EXTERNAL WASTEGATE
Super T70 turbo RM1600
This is a High Quality Turbo, with Big Wheels, Good For 400 to 500 HP Applications, Such as Mustang, Supra, RX7, and other 4-Clyn Engines with high Power Setup. Civic B18, B20, 240SX SR20DET, RB20, RB25, Eclipse 4G63.
PRODUCT
T70 turbo
specs
wet float bearings,
1/8 NPT oil inlet
compressor a/r = 0.70
turbine a/r =0.84
shaft and wheel trim = 58mm
compressor wheel = 56.5mm
diameter inlet 4"
oulet 2.5"
V band rear
oil cooled
T3 flange
rated to 600hp plus,
in stock now ready to ship
TD05H 20G RM1200
Features:
TD05H TURBO UNIT Utilize external wastegate Made of Quality Cast material Oil cooled & lubricated center section - journal bearing Suggested vehicle with1.6L to 2.5L engine: Up to 300-450bHP 3 Bolt Exhaust flange, 5 bolt downpipe flange All flanges pictured are included as well as internal wastegate
Turbo Specs:
Journal Bearing and oil cooled Inlet: 2 3/8", Outlet 1 5/8" Compressor :60 trim exducer 79.6 inducer 52 0.50 A/R Turbine: 77 trim exducer 49 inducer 50 N/A A/R
T25/T28
RM960
T25 Flange, Dimension: 73 * 40
Oil Cooled, Inlet: M10*1.5, outlet: 2 M8
Max Power: 270hp, spool time at 2500 RPM
Compressor Wheel
0.42 A/R Cold Side
Ind: 37.8 mm
Exd: 59.7 mm
Trim: 40
Turbiner Wheel
5-Bolt Standard
0.86 A/R Hot Side
Ind: 52.9 mm
Exd: 45.47 mm
Trim: 73
25-27 PSI Power Performance Output
Internal wastegate at 8PSI
CNC Machined Flanges
DEALERS WANTED -FREELANCE/WORKSHOP
CALL/TXT 0123505832
DREGO IMPORTS
49D JALAN PJS 1/48 PETALING UTAMA 7,PETALING JAYA
Tel: 0377811481
Malaysia ,New Zealand
Freelance/workshop/retail dealer inquiry welcome
xmas and mid year promo available .. turbo and intercooler
Have a good week ahead..cheers
Comes with 6month manufacturer default warranty card
Bring up post.dealer inquiry welcome
Buy any parts above rm1800 and get free 2 tickets to f1 malaysia gp on 8-10april
A Post Every 5 Mins
Battery Revitalizer (12V)
(Released on 25/09/2008)
Sulphation is a condition when the lead sulphate that is formed on the plates of a battery during its discharge changes in structure. Fairly large sulphate crystals are formed, which block the pores of the lead plates and hence reduce their active area. This causes the capacity of the battery to be reduced — it can no longer supply large currents and it can not be charged effectively in the usual way. The most effective way to break...
