- Nov 25, 2004
- 469
- 2
- 3,018
i have some major changes in plan for my Mini and therefore I have a lot of parts for sale. Some of these parts are brand new and still in the box. Most of the parts have been purchased new and seen very little use. My car is under restoration and some parts have been removed from the car. Parts are mostly kept by GT Auto in Sunway. I am now based overseas and do not have local number anymore, therefore the foreign number, you can reach me by whatsapp. Or please email [email protected] or PM me here. Basically I am selling complete engine, exhaust, carburettor, front and rear subframe and associated suspension components. List of parts as detailed below:
1.45DCOE Weber fully jetted n serviced to suit 1380 and with PiperCross Full Radiused Ram Pipe RM1800 - Ram pipe and jets bought new from UK
2.Weber Twin Cable Competition Linkage Mechanism - RM450 Used,Bought new
3.Maniflow 6in Steel Inlet Manifold RM500
4.36mm Rimflo Oversize Inlet valves - RM400
5.Fully Ported and Polished Head 9 stud head - RM1000
6.1275 A+ Block, 74mm Offset Bored, Honed with new water jackets RM1500
7.Complete engine and gearbox gasket set RM250 - Item New and still not used
8.74 mm ART-Mazda 808-model dome-top pistons with RIK Piston Rings RM400 -Used,Bought new
9.Modified factory con-rods (A+) to suit above pistons RM400
10.Factory crankshaft (CAM6232) RM400
11.Swiftune SW10 Billet Camshaft with matching valve spring, followers and oil pump RM1800 - Bought new and still not used.
12.ACL camshaft bearings RM150 - Bought new and still not used but fitted to block
13.Centre Main Strap RM100
14.ACL conrod and crank bearings RM600 - Bought new and still not used.
15.Kent Cams Adjustable Vernier Duplex Chain Cam Pulley RM1000 - Bought new and still not used.
16.Avonbar Balanced Ultralight Steel Flywheel with lightened and balanced Backplate RM1500 -Used,Bought new
17.AP Rally Clutch Plate RM200 - Used,Bought new
18.AP Orange Rally Pressure Plate RM200 - Used,Bought new
19.Factory Gearbox with Mini Spares Central Oil Pickup Pipe c/w 3.6 FD RM1500
20.Magnetic Oil Trap Sump Nut from Mini Spares RM100 - Used,Bought new
21.Aldon Yellow Race Distributor with vacumn advance RM750 - Used,Bought new
22.Aldon Ignitor RM500 -Bought new and still not used.
23.MOCAL 9 row oil cooler RM250
24.Extra Electric Fan RM150
25.Minishop Alloy Rocker Cover with Quick Release T bolts RM200 - Used,Bought new
26.Garage Auto Delta 3 into 1 large bore race manifold with complete piping and muffler RM2200
27.Alloy Dip Stick RM75
28.Lucas ignition cables RM80 -Used,Bought new
29.Lucas Sport ignition coil RM100 - Used,Bought new
30.Filter King Adjustable Fuel Regulator and Filter RM200 - Used,Bought new
31.Mini Spares 1:1 Straight Cut Drop Gear Set with Timkin Idler Roller Bearing RM1700 - Bought new and still not used.
32.Competition Diff Pin RM100 - Bought new and still not used.
Suspension
1.Minispares Forged Lower Arm with rose joints, fully adjustable camber RM800 - Used,Bought new
2.Minispares Heavy Duty Adjustable Tie Rod RM350 - Used,Bought new
3.Hi-Lo Alloy Ride Height Adjustables - Front and Rear RM400 - Used,Bought new
4.Spax Gas Adjustable Damper Front and Rear RM350 - Used
5.Fully Seam Welded Front Subframe - Injection model RM300 - Used
6.Mini Spares Alloy Solid Mount Kit for Front Subframe RM300 - Used,Bought new
7.Rear Subframe strengthened with extra weld points and complete with swing arm and rear drums RM700 - Used
Brakes
1.Factory AP servo & master cylinder - latest type RM300 - Used
2.KAD Alloy 4 Pot brakes (Anodized Blue) with Project Miu NF series Fast Road Pads and Cross drilled solid disc RM3300 - Used,Bought new
3.Goodrige Stainless Steel Braided Hoses RM250 - Used,Bought new
4.EBC Green Brake Pads to suit 4 pot brake caliper RM300 - Bought new and still not used.
Suspension
Brakes
