Civic radiator
sanekit
Dec 9, 2015
1,616
157
663
Not unless he's the sort who warms up his engine slowly .. like 10 minutes before each drive
i do that most of the time. i always see people post saying that it's unnecessary to warm up the car. is it true?
anyway since my stepper motor now is working fine, i would usually just start and drive off after a 2 mins or so.
sanekit
Dec 9, 2015
1,616
157
663
adjusted ? what do you mean by that? top overhaul?
where can i do this? how much does it cost?
top overhaul usually depends on what need to be change. eg valves, tappets (lifters), etc.
the price range around RM900-RM1300, again, depending on the parts. some shop just use OEM parts, so it's cheap. some use original parts, so it'll cost slightly more. some will never tell u what genuine parts they use and just charge u like ori. ahahahaha
cannot. can only add shim to reduce it. but best is to change the lifters or do top overhaul while you're at it..
My VR also run on hydraulic lifters, even 5w40 don't quiet them down, now using 15w40 HDEO have quieten them a lot.......lol
  • Like
Reactions: sanekit
iameternal
67
6
8
40
actually thought of doing top overhaul last time, but wasnt sure it will solve the engine noise problem or not..if need full overhaul, i think need 3k ba?
not planning to drive the car too long (plan to sel it), thats why still deciding whether to do anything for the engine
sanekit
Dec 9, 2015
1,616
157
663
change the lifters, problem solve. while you're at it, do top overhaul (grind-valve, clean the port, change head gasket, change all the oil seals/valve seal).
Once open up, see not right, usually will change. But if if carries on, the bill could be quite hefty.......lol
  • Like
Reactions: sanekit
Likewise, have a Hyundai and is smoking white smoke. Using 20w50 and a bottle of no smoke to run. Car seldom use and not worth much. If overhaul the bill could be quite huge so not sure want to do or not.......lol
Watch this interesting bit where the boys brought out the Mercedes-Benz S65 AMG, Rolls-Royce Ghost and "Bentley Mulsanne" for a review. Check how much can they blend their cars to the public and how a member of an Albanian mob demonstrates how useful their car is.
YouTube - ‪Driving in Albania - Top Gear - BBC‬‏
