Application:
Fits All:
EJ20 & EJ25 Engines
Intake Port Specs
Bore 66.5MM
Outer Diameter 70MM
48MM Muti-throttle Bodies
the funnels are made from Light Weight Aluminum for minimal air resistance. Fit with Stock Top Feed Injectors, you can retain the stock throttle position sensor,
you can retain the stock fuel pressure regulator.
Fuel Rail Included.
Each Intake Runner Is Made Same Length.
ITB Improves Response Of Your Engine,Gain Additional HP With Proper Tuning
Individual Throttle Bodies Allow The Engine To Operate More Efficiently By Decreasing Pumping Losses To Achieve More Horsepower.
Engine Will Rev Up Much Faster To Get Desire Power Band.
Design And Quality Of BLOX USA.
OBX backed warranty
this kit require proper engine management and tuning for maximum performance,this product will not work with factory computer
DREGO IMPORTS
0133505832
[email protected]
BANDAR SUNWAY PJS 7/20B
Fits All:
EJ20 & EJ25 Engines
Intake Port Specs
Bore 66.5MM
Outer Diameter 70MM
Fuel Rail Included.
OBX backed warranty
DREGO IMPORTS
0133505832
[email protected]
