B16a full engine overhaul
mADmAN
1,840
547
it depends on wat u wanna overhaul and wat parts will be changed... wats wrong with ur engine in the first place?
perhaps look into engine kosong..might end up being cheaper
mADmAN
1,840
547
valve seals are cheap.. even supertech ones goes for about rm200 per set. if its really the valve seals, then no need to bring down the engine which will be a cheap cost....but if ur piston rings are worn.. that alone is a diff story...
since the "damage" and repair cost can vary alot... suggest u bring it to a reputable workshop and get a quote of all the possibilities...
Whiteknight
Thanks madman for your advice.
Have been checking and the compression is about 90 for one of the pistons. Weak rings I guess. I have Been advised that on a budget basis to replace valve seals and made the b16a head to a 2Ll crv block with minimal changes to other areas except retuning the air fuel ratio.....rebuilding the whole engine with replacing the pistons n rings is a more expensive affair......I am on a budget so what would hondarians advice.....at a crossroad now.....pls share your experience if any......minimal road use more for track use......tq
mADmAN
1,840
547
if more for track use avoid the 2L conversion. reliability will be an issue
stick with B16A if u can... they are very reliable and have an almost perfect rod/stroke ratio making them very suitable for lots of revving.
u can try finding B16A blocks to just directly fit to ur engine. otherwise, B16B and B18C are also options...
ok..i got a timer n need to know d wiring how it works...
got two bunch wires....
1st bunch: green =?
Red =ACC (+)
Blue =?
Black = ground (-)
2nd bunch : orange=?
Purple = Handbrake
white= ?
and another hose i guess is for boost reading
Plz help me ok....thanks a million
*Photo borow from FarinaRacer.....thx man
