Alternator over heat
mines998
1,048
149
663
Hi! Folks
I having a problem with my alternator lose efficency due to high temperature. I need you all help me brain storm how to solve the problem. If you familiar with 6A12 engine you should know the alternator where is the located. Even with thermal warp but still too hot. My exhaust piping is side by side with alternator location around 1inch gap only. Any idea is ok for me...TQ
xtremeleo
3,247
464
5,183
can u reroute the zorst pipe sir? how did u determine the problem was with temperature?
mines998
1,048
149
663
The exhaust piping is no where to move already due to the confine space. During cool start my charging voltage is 13.5V but once the engine get heat up it drop to 12.6V if spray water on the alternator the voltage back to 13.5V so very obvious is the alternator losing efficency once get heat from the exhaust. Now I need a solution how to reduce the heat from exhaust to alternator...I even think can i put a fan to blow it?
shah5755
355
31
Pj....kch
doesn't it the exact position for alternator and the exhaust manifold for the engine?if yes i think u shud send ur alternator for check...if not u put extra thermal wrap to ur exhaust manifold....
mines998
1,048
149
663
The alternator is on ori position but the exhaust is re-lay out due to convert to single turbo. I think is my bad didn't foresee this problem during modding. Now I need a solution to reduce the heat at that area...anyone got a good idea?
minikar
161
Cyberjaya
How bout heat-shielding your alternator, those jacket-like aluminum thingy for car battery etc
Else, custom a carbon fibre to separate btw ur alternator and exhaust
A photo of ur engine bay would be nice :)
mines998
1,048
149
663
Ya thinking to buy those premium type alluminium sheild to cover alternator Is quite common use on those turbo car but the price is kinda expensive 1 square feet about SDG180 and need to order from UK. :bandhead:
^pomen_GTR^
7,000 RPM
7,514
1,690
The Mines
yep...try do aluminium plate heat shield to separate those two item... :adore:
mines998
1,048
149
663
minikar said:
Alamak...US? Local got distributor?
---------- Post added at 11:46 AM ---------- 6 hour anti-bump limit - Previous post was at 11:46 AM ----------
DanzEterna said:
can use the front extractor heat shield, i removed mine cos installed downpipe.....
i still keep it at home if u want it.
Thanks bro I see what I can do 1st....
mines998
1,048
149
663
xtremeleo said:
wrap the zorst pipe, and get a heat sheild for the alternator
Sorry think photo a bit miss lead the exhaust already wrapped...
Think should be current look.
minikar
161
Cyberjaya
DragStar at Kelana Jaya (Aman... , at the back of Kayu Nasi Kandar's row) carries this stuff, I bought my exhaust wrap there
A Post Every 5 Mins
Hi,
Anybody facing this issue, s90 70mm throttle body becomes sticky after the engine warms. It's very hard to drive during traffic jam, I tried to adjust the throttle body cable pulley screw , helped abit but still sticky.
