TCSIM,
It's depend on your headlamps(New,Old).Mostly it's easier for old one! cause
silicon glue will melt more quickly!then when you blowed,you must to obesrve
a plastic that look like soft or melt then that a perfect time to seperated.
For my experience, Do not use a normal hair dryer casuse It can't give you
more heat enought! waste your time,Anyway if you have an oven it's also used!
I'm not sure that 100-120 degree and 5-10 minutes.You need to find out dude!
ps.Enjoy your DIY and show me soon!
Yes, you can definately use an oven to do the job. It is all depends.
For me, I used 150 degree and check it every 5 min to see on whether the sealant is soften and melted. If not, put back for another 5 min and check again until you can separate them apart.
Be careful and don't just leave it in the oven without supervision, you will easily melt the lense as well. I experienced it when I tried to install an agel eye for my Hyundai Sonata.
After more than 10 times experiences in opening my headlights for both on my cars. Now, it is just a piece of cake.
My suggestion, do not use silicon, use the windscreen sealant.
Final suggestion, use gloves. You won't want to burn your hands.
Mclaren have completed building what seems to be a formidable force for 2008 after signing Finnish rookie, Heikki Kovolainen. The Finn found himself out of a job at Renault when the team opted for Nelson Piquet Jr. as their second driver...
