Air Filter Q
SurboNight
75
I decided to install a K&N air filter on my 1.3 Wira Injection, and I have a question before I put in one.What is the difference between standard slot K&N with an OEM one?I know open pod one can give u short range pickup but not long pickup.If I choose to put in standard slot K&N it will give any diff.or not?TQ
PS:I'm not a policeman.Dun worry with me.Just my avatar.:smile:
huakenny
LB Performance
9,126
240
Kota Kinabalu
open port n dropin serve the same purposes..
for open port u hv to do heatshiled,cai n rampipe to get beter result
meanwhile, drop-in is very easy..no heatshiled coz use back ori box...juz take oem filter out n replace by knn dropin filter...settled
original cai can be replaced by bigger size if u wish....no big deal (optional)
SkYwAlKeR
10,146
300
ePoh ~ malacca
but some say performance drop-in and OEM filters works almost the same...
u only can feel the different if change to open pod filters... not sure about that...
huakenny
LB Performance
9,126
240
Kota Kinabalu
erm...oem filter is not the same wit knn dropin..knn allow more airflow n less air restriction..
u can go eneoud there play the knn filer tester/machine....then u wil know perhaps
SkYwAlKeR
10,146
300
ePoh ~ malacca
yah, i played with the tester before, but not in eunos la...
plus, i havent tried drop-in performance filter before also... i heard people say so only... i'm currently using K&N ufo type filter (round one) on my 4g13 carbie...
nitrus
2,893
35
how u noe if it's not just one of their marketing strategies? :biggrin:
no la juz kidding ...
actually i think, drop-in and open-pod also same wan la ... just that open pod got the chun sound only ... and can extend to wherever u want ...
in the end, the air still end up being sucked in at the same place...
if u good in DIY , juz do some extending of your ori carb airfilter rampipe la... (that one u figure out urself) :biggrin: ...
u extend ady can get slightly diff sound ady wen air induction ..
then u change drop-in filter ma can ady lor ...
waste so much money go do open-pod for carb .. rampipe la, adapter la, dis la dat la... wahhhhh. -_-
sorry if wat i said up there is wrong.. plz correct me if wrong... hhehee...
taqu
207
Those drop-in airfilter performs just as same as original airfilter, the only advantage is the drop-in last alot longer. This fact has been proven on dyno.
For carb, it's best to use the UFO-shaped airfilter eg K&N as I'm using right now.
kent20
4,448
drop in K&N which means standard slot,just nothing different with oem filter...
open pod if u did a good Cold Air Intake which means CAI,that would be increas minor pick up...and the sound nice~~hehe....
offtopic:i just wash and reoil my K&N open pod yesterday....sakit hati...RM75 to buy the cleaner and oil...
Target Design
436
Pahang
n
**delete**
Target Design
436
Pahang
n
if i install open pod filter to 4G13p SIEMENS ECU and adjust fuel pump regulator to 46psi with heatshiled but no CAI....izzit will get more power...or better use back OEM airfilter with airbox and OEM fuel pump regulator??
Kelis
162
I think the K&n drop-in filter is different from that of stock because it can let in more air, n can be cleaned n re-used. The open-pod n the drop-in should be the same performance wise, but, with heat sheild n C.A.I. the open-pod will surely give more power.
Just my 2 cents... :smile:
SkYwAlKeR
10,146
300
ePoh ~ malacca
yeap... K&N filters are better than stock in long term... if ur stock airfilter is still new, i think compare with performance type nothing much difference... the difference is when ur filter gets dirtier and dirtier... coz dirty paper filter restrict alot of air...
Was the doomed Enzo wrecked by accident or on purpose as both tax write-off and generator of free press for producer Daniel Sadek's car-chase movie "Redline"? What's the difference? The putzes behind "Redline" laid the Enzo in state. Seriously, they put on a frigging wake, complete with wreaths, roses, framed photographs and a totally tasteless, $3 cartoon of an Enzo ascending to Heaven and then flying around in the...
