air filter and exhaust system
voon
111
hi everybody, i'm new here.......i own a proton 1.5 (m) 2002 which perform like a trishaw........ i am thinking of few modification without changing the engine.
First, i would like to change the air filter to a less resistance one........is it ok ? Which brand to choose and any precaution should i take ?
Second, the exhaust system........can i fixed up a 4-2-1 manifold ( extractor ) only and keep the rest original until the muffles, as i dun want loud sound.
Anything else i can do to increase some performance for my poor car ?
thanx
voon
cyclonite
858
If you change air filter, you have to decide whether to stick with the original type or open pod design. If you choose open pod, you will need to add pipings, plus open pod air filter and your car will sound different... very noisy. For open pod filters, check out K&N or HKS lor...
On the other hand if you want to use the original type of catridge filter, HKS has those high performance kind also where you can easilly change your standard air filter to this type just by replacing it... no need to modify the filter's housing or whatever.
Yeah change spark plugs to high performance ones, change your spark plug cables to less resistance 5 core cables or something similar. If got money, change your ignition system to more powerful one also so that it can produce a greater spark at the spark plug.
If you still want to go faster, w/o noise, w/o spending much....
check out www.turbozet.com or find out about Surbo turbo.
There are also systems like 'power jet' or 'micro compressor' heard of it? not sure how they work but they allow your engine to get more power and save petrol.
akimoto
324
fastest n easiest way to get power from your car -- NOS
Esky
150
Jun,
not everyone can afford or wants major mod mah! ;)
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
thanx
voon
Hi Voon,
Basic guides on Performance increase is Air Intake and Outlet.. (Which I think you already figured it out)..
For Wira, you can either Modify your Stock air filter to have a Drop in Filter Element or to remove it and replace with open POD.
:::: PROs of using Drop in and Original Air Box
- Cheap
- Original Heat Shield intact
- Stock Cold Air intake (Proton Wira / Satria)
- Not noisy
:::: PROs of using Open Pod
- More Power
:::: CONS
- Noisy
- Need to install additional piping (RAM Pipe)
- Need to modify Cold Air intake for better performance
- Additional Cost.
Next will be the Air outlet system.. Changing your extractor to 4-2-1 will give you a better acceleration... and also the size of your piping will help too.. But bare in mind, if you install TOO large pipings, you will decrease your performance...
sil
10
Maybe should tell him the reason why changing this or that will help increase in performance? Don't just simply change without knowing whats the main purpose. In a way he'll get more into cars :)
Cheers
voon
111
thanx everybody........
Still not ready for major mods.........scarry ma !!
After reading everything and considering...........this is my verdict
Ok.............I'll change my Air filter ( Drop in ) - close pod system and extractor (4-2-1 ) only, without changing the long pipe and the muffles. Its that ok ?? !!
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
HI Voon..
Yup.. that should be good enough... (For the moment).. :) hehe
umans are so hard to be satisfied. :D :lol: :D :lol:
simplythebest
1,978
Selangor
NGK spark plugs? how to choose? mine is a 1.3 GLi .. can I have the NGK brand model description name? there are cold and hot plugs right .. so I should go for?
do they have model like NGK 1,2,3,4,5,6,7,8,9? or maybe 1-4 is cold 5-9 is hot? :unsure: not sure .. high performance plugs cost around RM 200?
for spark plug cables .. go for splitfire? :ph34r: :unsure:
EG9
2,309
37
Subang Jaya
My brother have done some mod on his 1.3L, get good performance (still using original air cleaner) , able to beat 1.6L that had mod.
Actually my bro have tried a few type of air filter but still get the best "overall performance" with original air filter.
No doubt open pod air filter give you visible throttle respond, but the nightmare come after thrid gear.
3R1C
'(00) Super Moderator
409
9
Kelate/Penang
3R1C-MY.Blogspot.com
mind to tell wat's the nightmare?
voon,
ya...like they all said...changing air filter is a good way...
about that extractor...if changing to 4-2-1 and a larger diameter piping and stick with da original muffler...u will get a funny sound...coz i got a a 4-2-1 and a 2 1/4" piping but with the 1 1/2" stock muffler...i got a funny sound like "Prianggg....priang..." haha...kinda noisy sometime <_<
but anyway...no $$$ for muffler yet...so just stick with it...but i think u will get a better torque :)
em...a lot of minor things u can do to increase performance...sparkplugs...the cables...all already stated by sifu...
good luck... B)
cheers!
Eric
cyclonite
858
Ok since noone's replying my other topic, maybe I should ask the same question here. Does anyone know what a cat back exhaust do? How does it work? What is it for?
Thanks.
SPEEDSPiRiT
1,417
Selangor
kenny-lee.com
currently i am driving a 1.8T
i not yet change the piping.
normal 1.6 piping still about 1.8inch nia
or lesser
i dunno
boosting on 0.6 like that
still a GTI is beside me
cannot lose him
but it's for 200m test nia..
is it bcos of the piping?
antonio
Old Member
582
or lesser
i dunno
cannot lose him
there is a lot off things have to check....piping is one of them....exhaust and I/c piping.... B)
EG9
2,309
37
Subang Jaya
Originally posted by 3R1C+Dec 1 2003, 10:24 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (3R1C @ Dec 1 2003, 10:24 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin-EG9@Dec 1 2003, 04:59 PM
voon,
good luck... B)
cheers!
Eric[/b][/quote]
What nightmare?
lost power all the way untill 5th gear.
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
or lesser
i dunno
cannot lose him
Speedspirit !~ :blink: :blink:
1.8 T with normal piping ah ?
Your TURBINE will blow one day lah.. Too much restriction liau... You can change to a 2.5 anyday.. and you will feel almost 50% more power that the current setup.
Faster go change wei..
We have here with us a very unique car. Being one of its kind, this specific one is more than 5 years old but only holds 500KM in mileage. Reason being is this car had been stuck in our local ports for a very very long time. Cars stored in ports are usually fully exposed to environmental damage, which mean there is no chance that the car has had...
