A32 braking system ..advice please thks
Jun 20, 2010
Hello gay n gals
1. My balancing always unbalance in front wheel ... i have check more than 5 times , still not solve yet , is it possible the drive shalf problem ?
2. I have changed my drive shalf , but dun know why the brake system ...coz when i start my car n slow down press brake ...it feel like chock chock chock .... what wrong ?
please ....advice ....my fellow member .....
dream.tent
976
24
www.cardomain.com
Wheel balancing is normally due to:
1. Crappy Tire. (Swap tires or put new tires)
2. Rim itself. (Try swap front to rear)
3. On wheel balance it.
Your second part is a bit unclear...what is the problem? Drive shaft? Brake?
If you can hear grinding sound while braking, high chances your rotor is warped..
weikee
924
15
If the car have drive shaft problem, without braking also got problem.
Did the car had any accident? I remember when i swap my sentra with SR16, the left hand wheel was giving out funny klock klock klock noise. My mechanic say maybe shaft not fit and need to customized. but after some thought, and because the 1/2 cut was accident on the left. I ask them change the knuckle to my original car knuckle. Everything solved.
So you happen to own a Mercedes-Benz and love the German marque for all its bell and whistles as well as the status symbol it provides, and you wouldn’t have another stead in your stable unless it came from the company that Karl Benz and Gottlieb Daimler began in 1926.
<!--more-->This would seem to be the perfect opportunity as NZ Wheels is giving all its loyal customers an amazing...
