greetings to all 3 diamond's forumers, i am going to jump the gun and get straight to the problem. i have a mitsubishi lancer like the above model and have problems with my engine. the symptoms are as follows.
- Engine smoking white, sometimes when i rav it.
- Engine oil level goes down quite rapidly.
- No freaking power at all aka power loss.
- engine making hell of a lot of noise, (mechanic said that it could be tepet problems.)
- its a tiptronic gear box, but sometimes when i am goin up hill and gear changes it takes a while before a little bit of power kicks in.
Mechanics gave me the following solutions,
1) overhall the engine, change piston ring, grind valve(whatever that means), change all gaskets, etc, etc, etc. total cost for this he said would be a wooping 1K.
2) just top up the engine oil as it goes down, (like duhhhhhhhh i knew that)
another thing to note is that i have been changing between oils from normal to syntetatic and now to semi. I noticed that my tepet noice dissapear completely when i use syntathic.
ANY ppl out there able to help :help:! any help will do, even pointing out to a good mechanic would do.
thanks, live long and prosper......:ciao:
