Bro speed2horizon,
1.
Finally I've found one unit evo 3 gsr lsd box. The owner says dat its full-lock lsd. the code all check out rite (W5M33-2-UPWE)..
I try to look thru the drveshaft hole... cant see thru it. Is it consider like u say the lsd spacer?
Hope its an aftermarket lsd..
2.
if the box on floor how do i engage the gear bro?
3.
- When installing d evo lsd box what type/brand of gear oil do u recommend be used? Now i'm
running wit redline liteweight shockproof.
- Do i need to use kaaz lsd/tranny oil. If yes, do i hav to use the kaaz's oil solely (very expensive
![Bawling :bawling: :bawling:](https://zerotohundred.com/forums/styles/default/xenforo/smilies/bawling.gif)
) or can i mix it wit 2 litres/1 can of kaaz oil + 1 litre redline liteweight shockproof ?
[d box would probably need around 2.5 litres of gear oil rite..]
PS:
Open diff/nonLSD hav a shaft on d middle of d axle hole rite?
Gearboxes codes(copy&paste)
W5M33-2-WQFE - Evo 1 RS with front LSD 3.909
W5M33-2-WQGE - Evo 1 GSR non LSD 3.909
W5M33-2-WQWE - Evo 1 GSR with front LSD 3.909
W5M33-2-WQYE - Evo 1 RS non LSD 3.909
W5M33-2-WPFE - Evo 2 RS with front LSD 3.909
W5M33-2-WPGE - Evo 2 GSR non LSD 3.909
W5M33-2-WPWE - Evo 2 GSR with front LSD 3.909
W5M33-2-WPYE - Evo 2 RS non LSD 3.909
W5M33-2-UPFE - Evo 3 RS with front LSD 3.909
W5M33-2-UPGE - Evo 3 GSR non LSD 3.909
W5M33-2-UPWE - Evo 3 GSR with front LSD 3.909
W5M33-2-UPYE - Evo 3 RS non LSD 3.909
Thanx for d valuable advice
:cheers:
