Hi,
I have a set of the following 2jz-gte engine rebuild parts. purchased this for my forged rebuild but i might have to relocate to east malaysia due to job requirements so i dont have to rebuild my engine in the near future... better just sell this set first and rebuild later...
all items are in my possession ready for viewing, all genuine and brand new in box, purchased from the states.
all parts meant for 2jz non vvti turbocharged engines (supra jza80 & aristo jzs147) but some parts can be used on vvti engines and also 1jz engines. pls do ur research.
package consist of:
1. Wiseco forged pistons kit (with pins and rings) 86.5mm bore, 8.8:1 compression ratio
2. Eagle H-beam forged conrods kit (with arp rod bolts) standard size
3. ACL race bearings set (main bearings, conrod bearings, thrust washer) standard size
4. Fluidampr crank damper (sfi-approved) standard size
5. Gates racing timing belt (blue)
6. ARP studs kit (arp main studs, arp head studs, arp flywheel studs)
7. Crower racing single valve springs and titanium retainer kit (complete for all 24valves)
8. Cometic MLS head gasket (1.3mm thickness, 87mm bore)
9. Supertech viton valve stem seals (12x intake, 12x exhaust seals)
10. NGK BCPR7ES copper spark plug set (6units). favourite plugs among modified supra users.
this setup should be able to withstand whatever abuse u intend to give, provided that all items are installed properly and well tuned.
price for whole package - RM10k.
imagine the trouble we have to go through to go to shop by shop in sunway (and vicinity) to source for JZ parts. now its all available in a complete, brand new package with no waiting period.
location subang/sunway/shah alam, PM if interested.
optional parts: used set of brian crower 264/264 in/ex camshafts with a pair works campulleys
package consist of:
