nope, it's quite easy to find. this is the list i got from searching the web, 1jz parts are getting less and less, so i got to find alternative from 2jz parts. do some searching through the web. you'll find some interesting websites. pm me if you want a list. i'd love to get my car fitted with a 2jz but due to the road tax, i used 1jz. 2jz has more torque in the mid range than 1jz but 1jz head flows better.
2jz can use direct replacement of a 1jz water pump and fan assembly. so i think there isn't a problem of looking for parts. any one else wanna add some comments?
<table class="MsoNormalTable" style="width: 424.5pt;" border="1" cellpadding="0" width="566"> <tbody><tr style=""> <td colspan="2" style="padding: 0.75pt;"> [FONT="]Required Conversion Parts[/FONT][FONT="]<o:p></o:p>[/FONT]
</td> </tr> <tr style=""> <td style="padding: 0.75pt; width: 261.75pt;" width="349"> [FONT="]Description<o:p></o:p>[/FONT]
</td> <td style="padding: 0.75pt; width: 150.75pt;" width="201"> [FONT="]Part No.<o:p></o:p>[/FONT]
</td> </tr> <tr style=""> <td style="padding: 0.75pt;"> [FONT="]Toyota 2JZ-GTE high pressure power steering hose
Substitute found @ partsamerica.com<o:p></o:p>[/FONT]
</td> <td style="padding: 0.75pt;"> [FONT="]44403-14020<o:p></o:p>[/FONT]
</td> </tr> <tr style=""> <td style="padding: 0.75pt;"> [FONT="]Toyota 2JZ-GTE power steering union bolt<o:p></o:p>[/FONT]
</td> <td style="padding: 0.75pt;"> [FONT="]90401-16014<o:p></o:p>[/FONT]
</td> </tr> <tr style=""> <td style="padding: 0.75pt;"> [FONT="]Toyota 2JZ-GTE throttle cable<o:p></o:p>[/FONT]
</td> <td style="padding: 0.75pt;"> [FONT="]78180-1B090<o:p></o:p>[/FONT]
</td> </tr> <tr style=""> <td style="padding: 0.75pt;"> [FONT="]Pressure port gasket #2<o:p></o:p>[/FONT]
</td> <td style="padding: 0.75pt;"> [FONT="]44327-26020<o:p></o:p>[/FONT]
</td> </tr> <tr style=""> <td style="padding: 0.75pt;"> [FONT="]Pressure port gasket #1<o:p></o:p>[/FONT]
</td> <td style="padding: 0.75pt;"> [FONT="]44327-12010<o:p></o:p>[/FONT]
</td> </tr> <tr style=""> <td style="padding: 0.75pt;"> [FONT="]2JZ Valve cover gaskets<o:p></o:p>[/FONT]
</td> <td style="padding: 0.75pt;"> [FONT="]Int 11213-46020
Exh 11214-46010<o:p></o:p>[/FONT]
</td> </tr> <tr style=""> <td style="padding: 0.75pt;"> [FONT="]Toyota Supra 89+ front crossmember<o:p></o:p>[/FONT]
</td> <td style="padding: 0.75pt;"> [FONT="] <o:p></o:p>[/FONT]
</td> </tr> <tr style=""> <td style="padding: 0.75pt;"> [FONT="]Toyota Supra89+ fluid motor mounts or custom mounts<o:p></o:p>[/FONT]
</td> <td style="padding: 0.75pt;"> [FONT="]12361-42050<o:p></o:p>[/FONT]
</td> </tr> </tbody></table> [FONT="]<o:p> </o:p>[/FONT]
<table class="MsoNormalTable" style="width: 424.5pt;" border="1" cellpadding="0" width="566"> <tbody><tr style=""> <td colspan="2" style="padding: 0.75pt;"> [FONT="]Optional Parts[/FONT][FONT="]<o:p></o:p>[/FONT]
</td> </tr> <tr style=""> <td style="padding: 0.75pt;"> [FONT="]Denso Platinum Plugs
Denso Iridium Plugs(sku 5304)
NGK Platinum Plugs(sku 2215)
NGK Iridium Plugs(sku 6418)
Gap <o:p></o:p>[/FONT]
</td> <td style="padding: 0.75pt;"> [FONT="]PK20R8
IK20
BKR6EP-8
BKR6EIX
0.32in (1mm)<o:p></o:p>[/FONT]
</td> </tr> <tr style=""> <td style="padding: 0.75pt;"> [FONT="]1JZ Timing belt(JDM only)<o:p></o:p>[/FONT]
</td> <td style="padding: 0.75pt;"> [FONT="]13568-49025<o:p></o:p>[/FONT]
</td> </tr> <tr style=""> <td style="padding: 0.75pt;"> [FONT="]1JZ Serpentine belt or
2JZ Serpentine Belt<o:p></o:p>[/FONT]
</td> <td style="padding: 0.75pt;"> [FONT="]90916-02306
90916-02309 <o:p></o:p>[/FONT]
