200bhp possible from a neo 1.6 campo?
in a few more minutes,
proton basher will start to flame this thread
since thread starter from uk, can google campro turbo
got 1 campro BOT using stock internal, boost @ 0.5bar. Dyno result on crank can reach 200hp+
campro turbo dyno 225 HP
[YOUTUBE]XOWAxH4ls4A[/YOUTUBE]
wonder how much hp can gain if using low comp piston & strengthen internal part... boost more than 1bar
campro n/a mod can go up 170hp
1.6 can go up to 500hp also la.. a mazda mx5 did that in Hot4s mag.. go check it out..
dont compare Mazda to a Proton. CamPro engine can be brittle if not properly done..pretty robust when properly done.
with "taufu" internals, the weak link is the crankshaft ( non-CFE model ), thin rods, thin valves, small oil galleries, small water jacket...how to control heat that is building up inside the engine itself ?
there's a fine line between driving it confidently ( reliable ) and destroying it the next second if one decides to pull so much horses.
maybe with stronger internals and improved lubrication ( circulation ), fueling, cooling, that much horses is achievable. not to forget, the "brain" must also be upgraded.. alot to consider.
as my own experience.
a normal campro can be safely boosted up to 1.0bar.. with stock internals. normal whp range is between 160whp - 180whp. again whp.!
for campro cps.. easily can get 180 - 200 whp. i've seen a gen2 cps with forged piston, metal gasket, trinity clucth and walbro pumps out 255whp.! the car still running healty for years :driver:
---------- Post added at 01:04 PM ---------- 6 hour anti-bump limit - Previous post was at 01:00 PM ----------
Suddenly this thread reached 2 pages..
is 200 horses possible ?
a gen2 1.3 auto.
has been bolted on since 2008 if not mistaken.
result is quite impressive.
150whp with e-manage.
180whp with haltech. :adore:
its whp. so do the math for bhp.
i doubt it.
1 horse weights an average 400kg~450kg, 200 horses is around 80000kg, thats 80 ton. No way in hell a Neo 1.6 campro can carry that many horses. :rofl:
i doubt it.
if like that.
an 18 wheel trailer cannot fit 200 horses.
:rofl:
i doubt it.
wakakakaka..initially i thought this is some good formula for horse power. then..wait a minute. got trolled :rofl::rofl::rofl:
Lol... Lets get back to the point as i want to start the evo swap or mod"in my compo ,
spoken to speedworks and they say 200hp will blow the engine
then they are quite literally dumbasses. if this 1.5L 1NZ-FE from a Vios (or Yaris in UK) can make 500bhp, I don't see why a 1.6L Campro cannot make 200hp.
[youtube]QJsQSzo7gb0[/youtube]
With turbo, it basically depends on how much you're willing to spend. The more you spend, the more power you can get. But again max power is not everything. How the power is delivered is the most important thing. Having very high max power but with a peaky power curve will practically make your car slower in real daily condition and makes it harder to control.
most probably campro will blow with high boost..
even with NGV the conrod got broken.. it's the quality of material they use..
if it was me, i'd blow my engine 1st..
only after that i'll go search for a new engine with lots of power :biggrin:
Gudluck :burnout:
Gudluck :burnout:
ha..ha..ha..i try its once with owner,not neo la...take out all engine oil then drive till the engine jem..and tow back to w.shop..just want to see how far its can go..so stupid crazy that time...:rofl:
speedwork no use laa.. :banghead:
after many years. they still don't know how to boost a campro. :rofl:
even their blue printed campro supercharger blew if not mistaken.
register camproturbo.com
there's lots of campro turbo member.
some of them already bot for more than 5years w/o major prob.
get their opinion.
p/s:the product owner also give warranty on engine realibilty.
actually, any engine can be turbocharge..
it's what u put inside the engine that's gonna make it reliable or not..
forged piston & conrod is a MUST.. if u wanna get more power..
if u use stock/standard piston & conrod.. the chances of getting problem is high..
so, do ur research..
looking at camproturbo.com the video.. i'm guessing the Satria Neo already put forged internals :biggrin:
anything is possible, only cash problems, even a waja 1.6 4g18 BOT can get 199.1whp now days. keep up the good job there bro.. cheers...
