160000KM Service...
NiCkY7
821
Hi all,
currently my car reach 160000KM liow...
will be going to service in these few days, so i need to know which part i need to check and concern...
these are i already marked down,
1) Clean Throttle Body. (Is it my spelling right? cause wan to write on paper for mechanic) :P
2) Auto Transmission Fluid. (erm, not sure when got changed, or maybe didnt... cause last time is my father using these car.) :lol:
3) Power Steering Fluid. (These wan important? currently still in normal level.)
4) Fuel Filter. (These i think never change before.) <_<
5) Brake Oil. (These wan important? currently still in normal level.)
6) Clean Fuel Injector. (Last three month i just use the Redline Fuel System cleaner, but didnt feel any improve, dunno whether got clean my injector or not.) <_<
Anything i left?
Currently my engine vibrate quite keng, these happend when i deaccelerate and the RPM niddle drop down to 400RPM then climb back to 800RPM normal idle RPM place.
And this also will happen when i change the gear from N to D4 and i didnt accelerate, the RPM niddle also will drop to 400RPM and the engine start vibrating...
Does clean the Throttle Body will help this problem?
Thanks...
g88
3,081
54
5,148
When was your last change of your timing belt and water pump ? Check that also if last change was at 80K
NiCkY7
821
timing belt i think change between 100K - 110K KM... not sure the real KM... so currently the timing belt still ok, when rev kao kao, didnt have any sound... :D
water pump? u mean the radiator pump? sorry not sure about this... :(
gibod_78
1,550
11
fren.. timing belt dont wait till got sound.. more 80,000km better change woo.. :blink:
later u heard the 'snap' sound.. then... :( too late oleadi..
NiCkY7
821
i know... but i change between 100K and 110K KMs, so now only 160K KMs, just around 60,000KM used...
alantan
3,573
15
kl
my car 13 years...
i think he milage suppose to be 140000km...what i had after that was leaking..hahahha
NiCkY7
821
Originally posted by alantan@Aug 27 2004, 11:27 PM
my car 13 years...
huh? :huh:
u saying my car 140000KM? no ar, 160000 lo... 7 years only... :P
didnt have anything leaking yet,,,, choi choi choi... :P
g88
3,081
54
5,148
Originally posted by NiCkY7@Aug 27 2004, 12:53 PM
[QUOTE
[/quote]
Well if you are driving Proton, you need to remove your timing belt, tensioner all then can change the water pump.
Since it's not easy to change so NORMALLY ppl will change during each change of timing belt.
Sometime it might be tiny leak that you can see....
m a v [3] r i c k
9,000 RPM
9,074
27
have your mountings checked as well :)
NiCkY7
821
Yo guys...
thanks for all the reply...
i did my car service at yesterday liow...
change oil filter and normal mineral engine oil (later add Tufoil) can better than semi sync... haha...
then clean my Throtte Body, change fuel filter and ATF also...
my car now didnt vibrate like hell... and the idile timing stable also, since the TB are already clean... :D didnt add tufoil yet :P add liow should more keng... haha...
OK, now got other question liow... :P
Did the STP Fuel System Cleaner is ok? really work?
thanks... :D
ocean
110
:blink: 100 to 110 K change timing belt ... risky wo ....
i not dare to take this risk .. i will change on 80 K .. :unsure:
NiCkY7
821
i think around 60K got change before...
cause last time is company car, service at Honda service center... The SC guys sure will RECOMMEND change at 60K... somemore masuk company account, so change already liow...
now buy over the car and bring to a cheaper workshop, but MORE better then SC... wont cincai charge u about this and that... very jujur and experiences mechanic :D
Hi Guys. I need some pointers regards to my car. Im driving a Lancer 2005 1.6 CS3 GLX Manual. Its fully stock. Can I know what mod I can do for faster pick up n low to mid end. Can match a EG preferred. Which Evo parts I ca use? Thanks.
