L2 / L5 ecu mod- no Boost CUT
E-Tech
1,115
256
3,183
Johor
L2 / L5 Ecu mod- No Boost cut
Hi all car mod...
Well I would like to share on the way and method to remove boost cut
for those that have transplanted turbo L2/L5 into their kancils.....
Actually it can be done very easily and cheap at the ECU aka computer box.
But not many ppl out there know the secret.... i have seached and yahooed and goggled, i know there is no FOC answer... malaysian are not like mat salleh, do not post up their diy projects. Maybe also because wanna make money....
You know after some reverse enginneering and checking what ppl do and charge RM150-300 is just a cheap RM0.50 DIODE!!!!
SO far I have done this modification for 5 kancils with L2 ecu with success.. 2 drag cars and 3 street running car.... all have confirm that no boost cut and rpm now cuts at 9500..a/f is good range and can feel the power...
Just image ....RM0.50 modification... so for those DIY, if you are interested... pls pm me...FOC
km_chew
456
26
3,028
Now only got free ... I spend this amount to during my youth for this so call Diode.
spec-c
1,830
112
TTDi
Hmm another way is to remove your TPS wire... but that brings 1001 problems...
HKS-GT2835R
1,193
83
5,148
kelate
Hi all car mod...
if you're talking about the zener mod, you've got to consider fueling upgrades as well. by limiting the map sensor of the voltage, means the car's ecu is oso running 'blind' after so-so rpm.
E-Tech
1,115
256
3,183
Johor
Well, you are close but the value of the diode is important...
Knowing when the boost cut in ( in voltage) and then "clamping" it , is the trick.
So anything below the original boost cut limit will be normal( original A/f map).
Anything more than 1bar will definately needs to compensated... that is why minimun upgrade
after this will be at least a 5 button SAFC...
Anyway I have done a/f checking with wide band O2,...a/f ratio will not be a major issue with this mod...
Those that upgrade cc, and bigger turbos will definately have piggyback mgnt...
CONCLUSION: IF YOU VERY OFTEN RUN MORE THAN 1bar BOOST, PLEASE UPGRADE YOUR FUEL
MANAGEMENT. TQ...cara murah, tukar injector GSR/VR4 auto (RM150) @ masuk 5 Button SAFC.
(RM350-$450)... Too BAD ecu L2/L5 cannot "Chrome" or "HONDATA"... lucky also cos jimat duit dari caj "tuner" & "dyno"..... Jgn marah.. KUANG KUANG KUANG!!!
rudilaa
5
Terengganu
Thank You bro E-Tech,
your idea is working
I DIY today and
it tested and proved that the boost cut is gone.
E-Tech
1,115
256
3,183
Johor
Rudilaa...
You are Welcome!
Hope you received the files I send for you to DIY your 5 Button SAFC.
rudilaa
5
Terengganu
Terima kasih sekali lagi kepada bro E-Tech...
SAFC dah siap pasang... sendiri sambung jer, refer pada manual yang U bagi...
senang jer.... thank you bro...
E-Tech
1,115
256
3,183
Johor
You are welcomed.
Now you can support your friends for these 2 DIYs.
Jangan sembileh tau---- upah rokok dan redbull cukuplah...
BR
BBRAYCER
3,076
www.bbraycers.com
Testament to the boost cut technique by ETECH. Very good and clear and concise instrcutions to install. Engine never choked up to 1.1 bar. Installed on freinds car. boost is managed by the local made boost controller "cap tulang ikan". He claims that it is now a joy to drive. Bravo th ETECH for a great share and many sifu ratings for him. Hail Onkel ETECH! (just joking)
Bottom line to suspicious crowd out there. It Works up to 1.1 bar. hehehe after that you are on your own.
rudilaa
5
Terengganu
It's nice to drive with no boost cut.
But I only set to 1.0 bar only... safe side
hehe... it's enough for me...:driver:
E-Tech
1,115
256
3,183
Johor
Rudilaa, bbraycer wat to test power with you. Can kah?
E-Tech
1,115
256
3,183
Johor
Turboyaki(sabah),
Pls chech your email... Instruction and manual for L2 DIY SAFC digital has been sent to
you.
For the boost cut component, I will be posting it out 2morrow....
Pls report once modification has been completed. Tq & happy boosting...
Turboyaki
11
1,503
Kota Kinabalu
ok..thanks a lot for the instruction manual of SAFC..
and i would like to ask..how bout getting rid of fuel cut and speedo meter cut(can go over the maximum speed provided by the meter)..?:confused:
E-Tech
1,115
256
3,183
Johor
Turboyaki...
For L2, it is very easy to remove the speed cut...
Just cut the wire going to the ecu....
To know which wire, see inside the ecu.... it is marked as 'SPD' on the board.
I have posted out the component today , that modification will remove the boost cut, increase the rpm cut (9K) and MAYBE remove the speed cut also... - if cannot then only cut the wire lor...
OK?
Now a days one of the most popular car modification is modifying its back part with a new set of exhaust system.The addition of sports muffler or installing an entirely new exhaust system surely have some performance benefits however I will restrict myself only to the "appearance" benefits.New exhaust system sure have some big bores so you will need to cut the part of rear bumper in order for the muffler to properly fit.Extra care is needed when the rear bumper is quite thin.
Since the...
