Buy An Exhaust System For Your Car
saadi123
Karachi
Now a days one of the most popular car modification is modifying its back part with a new set of exhaust system.The addition of sports muffler or installing an entirely new exhaust system surely have some performance benefits however I will restrict myself only to the "appearance" benefits.New exhaust system sure have some big bores so you will need to cut the part of rear bumper in order for the muffler to properly fit.Extra care is needed when the rear bumper is quite thin.
Since the exhaust system of the car has to directly cope with the heat of the entire machine so consideration has to be paid to this side and one should make sure to leave ample space between the rear bumper and...http://carz4mod.blogspot.com
Don't confuse exhaust system with the mufflers.Mufflers are the part of exhaust system.
wow.. heavily promoting your web site.. ^^
then wat is the Exhaust System in ur terms..??? i would like to learn a bit from u....
Since the exhaust system of the car has to directly cope with the heat of the entire machine so consideration has to be paid to this side and one should make sure to leave ample space between the rear bumper and...Read More At Modify Your Car
nowadays? you meant last time no one modify their exhaust system?
btw, exhaust system is considered back part of the car? :adore:
"addition of a sports muffler or installing an entirely new exhaust system surely have some performance benefits however i will restrict myself to the appearance benefits."
<--- you sound confused bro. so got performance or is it just appearance? :hmmmm:
A thread every 60 seconds
