Regamaster offset on Wira 1.8
karem
Not Seniorita
567
24
putralalala.blogspot.com
Can offset +45 provide sufficient clearance for stock calipers? is it too deep?
Thinking of using this offset for Wira 1.8 with stock calipers...
Say if later change to twin pot calipers, would it also be OK?
Just want the tyres to be deep in the arches.
thanks in advance.
karem
Not Seniorita
567
24
thanks for the advice. but just want to know is +45 too deep & will collide with caliper?
has anyone used this rim on wira following this offset / setting?
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
team99ers.2.forumer.com
for some other car it will, cos the spoke r way too straight...
AD_EG
6,328
231
Ipoh
bro..i thought the bigger the number the outer it is?? if its much outer sure can clear stock caliper right?
the smaller the number ..the deeper it is right?
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
+55 =inner, +35=outer, -10=super duper outer... ehehhee...
m a v [3] r i c k
9,000 RPM
9,074
27
Satria GTi stock rims are +46 if I'm not mistaken.
But it depends on the design of the rims as well (if you are using big brakes...stock ones are puny and shouldn't be much of a problem to suit most rims).
+45 shouldn't be a problem for Protons with twin pot even, but it won't look nice as the rims will be sitting too "inside" of the body. Very noticable especially on the front.
Try getting +38 instead.
+33 hits the rear arch unless really knock/roll it flat.
Never tried +35. But if it clears the rear arch, will definitely look good :)
Similar threads   Forum
  Similar Threads
I bought a crime fighter alarm about a month ago. The alarm was what i consider as SHIT alarm as the problems occured one by one. First the proximity unlock is TIPU one. Then the spare remote control was unuseable. I called the seller, Auto Option. But the seller said nothing la. Then i email Megatronic Malaysia but the company never respond. After that the Big problem occured. The alarm module got problem. I called the seller again but she bla..bla..bla.. So now i cannot claim for the...
